Question about hood and front quarter "inserts"
Old Feb 8, 2006 | 10:17 AM
Taco's Avatar
Default Question about hood and front quarter "inserts"
I am thinking of having the plastic inserts in the hood and behind the front wheel powdercoated, but I don't know if they will stand the heat required to "set" the powdercoat.
Has anybody tried this or does anybody know if this would be possible?
Thanks in advance!
Taco
Old Feb 8, 2006 | 11:45 AM
camaroextra's Avatar
i dont know if powder coating is necessary. you can get pretty much any texture or gloss finish out of rattle cans these days
Old Feb 8, 2006 | 11:48 AM
'Trust''s Avatar
You dont need powder coat, get a rattle can with the color of your choice and have at it
Old Feb 8, 2006 | 02:17 PM
RollTideTA's Avatar
There's a guy around here that painted his yellow with a rattle can a couple of years back. Must hold up pretty well ... unless he repainted secretly
You could always get some from muffinbuster on ebay though that are stainless
Old Feb 8, 2006 | 03:33 PM
nhra-trans-am's Avatar
Moderator
Spray paint will work and it's much easier
Old Feb 10, 2006 | 09:38 AM
Taco's Avatar
I have a friend who just got a powdercoating system and I was going to let him coat them both to help him out a little and give him some practice. They are spray painted now, silver, but it is starting to flake off so I just thought I would try PC.
Does anybody know if they will actually stand the heat, he said they will have to withstand 400 for several minutes. Sounds like they might warp at least, but I might go ahead and get some in the stock black and let him have a go at them just to see. If they do survive, great, if they don't, now we know!!!
Thanks for the help thought guys, I know y'all meant well!
Taco
Old Feb 10, 2006 | 10:00 AM
01 Red WS6's Avatar
You can't powder coat plastic. You can only powder coat metalic parts.
Old Feb 15, 2006 | 04:21 PM
Taco's Avatar
That's what I needed to hear, thanks!
Taco
Old Feb 15, 2006 | 04:52 PM
Luna's Avatar
I spray painted mine a while ago, the first time I just sprayed them red with some rust oleum plastic paint, they looked good for a few months then started to fade pink.
So I took them off and resprayed them red , and put a few coats of clear over that, the clear has really done a good job of protecting it and they still look like the day I sprayed them!!
Old Feb 15, 2006 | 05:05 PM
MrPongoSS's Avatar
Powdercoating will destroy them.
Old Feb 15, 2006 | 05:08 PM
meissenation's Avatar
yeh, powdercoating requires baking and an oven, plastic would melt.
Old Feb 16, 2006 | 02:27 PM
Taco's Avatar
Taco
Not to be rude... but I already knew that. I know they can withstand at least a couple hundred degrees, so I didn't know if 400 would be all that much of a stretch.
Thanks, I guess I will have to media blast the flaking silver off (will also give a good texture to spray on) and do them again, with clear!!!
Thanks again!
Taco
BTW, sharp ride and nice pic, Luna!
Old Feb 16, 2006 | 04:42 PM
MrPongoSS's Avatar
Media blast it would be the best... another thing you can give a shot if you are careful is take some Grafitti Remover (3M, I believe), spray it on there, wait until the finish starts to swell, and then remove it. Do one section at a time. Don't let it sit on there too long, or it will destroy the plastic and make sure you clean it very well with soap and water after you get done.
