Hood pins, a quick poll
it wouldn't be bad though on a big cowl hood (93+ Camaro)
ditto, when i had the 4 3/4'' cowl hood i was gonna get them, even bought the stuff but never put them on
on a stock hood, i say no
You'll have to use your imagination for the nose & headlights.
Here's my LT1 (which needed them because the hood was repaired and scared me, flew off once):
Here's my friend's LS1, his car needed them because he made the hood himself out of carbon fiber (if it looks familiar it's because Harwood copied it shortly after he won the SLP Day show):
My current LS1 does not have them but if the hood warranted it and it went with the car I'd do it.
You just have to choose the right hood pins as well. I went with the old Chevelle style for the LT1, he used the newer latch style and Zeus clips for the LS1.
Street car I see no reason and if you need them from swapping hoods you bought a poorly made hood I've had cars with fiberglass and C/F hoods fit better then stock.
I think they look silly and if you need them on the street you got screwed buying a poorly fitting hood.
Some aftermarket hoods DO NOT HAVE the bracing required to make them strong enough to support struts and/or and hood latch.
The do not have it to make them LIGHTER and simply use hood pins to hold them down again making them MUCH LIGHTER without the bracing and hardware required otherwise.
I know some hoods don't I feel that it's a poor way to offer a hood for a street car. I've seen fiberglass and C/F hoods with bracing and still be quite light. Why anyone who drives daily or on the street at all would save 1 lb but use pins instead is kind of silly in my view.
I just feel they look tacky its just my view though.
I agree as well though, they have to be done right and be out of neccessity. Other wise it's kind of retarded.
