4th Gen Z28 Spoiler Removal?
Hows it going?
I'm looking to remove my stock Z28 spoiler. I checked in my Chilton Manual but it doesn't show any bolts? Are there any bolts involved to remove my spoiler? If so where are they?
Any advice or help on how to remove my spoiler would be grealty appreciated.
Thanks in advance.
Thanks in advance.
Simply remove the plastic trim cover beneath the hatch by pulling gently, the plastic auger clips will snap right back in when you put it back on. Unclip the 2-wire connection for the 3rd brake lamp and remove the 2 nuts on either side, 10mm if I recall. You will see the nuts once the plastic hatch cover has been removed. Then the spoiler will simply lift off the hatch.
