Foglight Bulb
-Joel
You can replace them with the SilverStar version (880ST).
The SilverStar version is whiter, but I dont know about brighter.
(I do have them on my Formula though.)
I dont know what 894 is....it that the 37.5 watt version?
If so, many on here have experienced melted foglight housings from the increased heat output of the higher wattage.
You could try putting in #885 (#886 for Camaro) which are 50 watt/100 candlepower bulbs but these have been known to cause enough heat to melt the plastic sockets and warp the lenses.
The only difference between the Firebird bulbs and the Camaro bulbs is that the Firebird uses straight in connectors while the Camaro uses right angle connectors.
