Finally have the quarter panel dents...
I still am dent FREE!!!! i do have a 2" scratch though
I dont think they will be far off, i have heard that SFC will still leave you with some quarter wrinkles?!?! is that right, or am i way off base?
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
My T/A 'aquired' the small creases on rear fenders in same place both sides above center of wheel while power was still in stock form.
I too had them taken care of with PDR (but no holes needed to be drilled). I installed SFC's right after that and they have never come back, even with the numbers in my sig. I have seen the exact same creases, in the exact same spot on many of my friends T/A's so it's not a coincidence, and it is DEFINITELY from body flex - even with power at stock levels.
Originally Posted by chupr0kabra
Not at all. Guy charged me $100 each for the two rear quarter panels. I met him at an Acura dealership on a Saturday morning and he had it done in about an hour and a half.
He set up a bunch of lights and mirrors, then drilled a small (0.5") hole inside each door jamb, then worked the dents out from the inside. He filled each hole with a rubber grommet, so if I ever need it done again, he will have easy access. I've attached a picture of the grommet, to give you and idea.
-Mike
-Mike
im sporting some, mine are higher then anyones door, plus I dont park close enough to anybody..You cant even see my car from the front doors at Wal-Mart LOL.. Mine arent from somebody.. I assure you
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Both my cars are dent free.(Knock on wood)
I used to have 1 on each side of the Trans Am but it just got completely repainted recently, so everythings nice and new there.
The Camaro is still doing good too, even though some lady blatantly opened her door into it in a parking lot the other day while I was sitting in it! Thank god the doors are a plastic material and cant dent and she hit the rubber trim piece so luckily there was no real damage, but I still flipped out on her and asked her how she could be so ignorant and rude. It wasn't even an accidental tap it was a complete open the door right into the car, it still pisses me off to talk about it.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
