quick! how do you remove rear view mirror
Old Mar 4, 2006 | 10:28 AM
pistolpigg's Avatar
Default quick! how do you remove rear view mirror
The guy tinting my windsheild strip doesnt know how to remove the newer rear view mirrors(just startin out). do you have to have a special tool? he said someone told him if you didnt have the tool you run the risk out breakin the windshield.
Old Mar 4, 2006 | 12:27 PM
Zymosis's Avatar
Well considering they can just randomly fall off, the glue can't be that strong.
I'd start by heating it up with a heat gun (from the indisde around the base, or on outside of window), then use a puddy knife or something similar and go around it. If the glue doesnt come loose, I wouldnt push your luck with prying. But I have never heard of it breaking a windshield.
Old Mar 4, 2006 | 12:29 PM
'Trust''s Avatar
You have to slide it up the windshield, it will come off. Do not pull it down or straight off, I tried that and took a chunk of my windshield with it
Old Mar 4, 2006 | 12:37 PM
pistolpigg's Avatar
is there any clips holding it on?
Old Mar 4, 2006 | 12:52 PM
DirtyBird222's Avatar
no, it's just on there really tight, it took me a good hour of pushing and prying it up before it finally came all the way off. best bet is to loosen up the glue, I wish i would have done that because my rear view mirror joint/bearing is loose and every time i get on it a little bit it moves and i'm looking at the backseat instead of whats behind me on the road haha.
Old Mar 4, 2006 | 02:27 PM
2K2WS6TA's Avatar
There's a set screw in it (looks like a t10 size) loosen the set screw, and slide the mirror up and off the mount pad that's glued to the windshield, leave the mount pad on the windshield, and have the guy tint around it (if he can't cut the tint to fit around that, get another tint guy)
Old Mar 4, 2006 | 04:52 PM
Guy2626c's Avatar
Thats 100% right, i had to tighten mine, cause i guess i didn't tighten mine last time i took it off. I had to catch the mirror at some point.
Old Mar 4, 2006 | 07:36 PM
thunder95ta's Avatar
The rear view mirror is easy to remove.. All you have to do is find a small flat head screwdriver (2.4mm) head and insert into the base of the mirror. There is a small slot on the bottom if you look. Insert the screwdriver until you feel tension and move the screwdriver up at the same time, slowly move the mirror up kind of wiggling it and it should come right off. I did this to install my compass mirror on my car. This was on a 1995 Trans Am, but if you have a wedge mount mirror it would still apply. Good Luck!! It took me like ten seconds to get the mirror off. Just like 2K2WS6TA said if the tint guy can't tint around the mounting button you might want to get another tint guy!!
Old Mar 5, 2006 | 01:13 AM
pistolpigg's Avatar
thanks
Old Mar 5, 2006 | 01:24 AM
You are welcome!!
