having trouble with !wire mod
-removed plastic inner fender
-disconnected wire harness and vacuum line
-diconnected the harness that connects to the caliper
now i cant get the wire pulle dup through the engine bay that connects to the caliper, and i just realized i dont have a "bi metal hole saw"
what are the solutions to these problems?
i cant get regular drill bits to get through the inner fender so if i cant get the hole drilled, im gonna hafta put everything back together and waste a day.
any suugestions?
). This way I didn't have to cut a huge hole in my fender to fit the connectors through, and the two smaller holes are very difficult to see.
). This way I didn't have to cut a huge hole in my fender to fit the connectors through, and the two smaller holes are very difficult to see.pics??
). This way I didn't have to cut a huge hole in my fender to fit the connectors through, and the two smaller holes are very difficult to see.That's the way I'm doing mine. It will be a lot cleaner after you finish too
After my dad pointed it out, it was much easier to get to from under the car.
