paint messed up on hard top
Old Mar 26, 2006 | 10:33 AM
hardtopz28's Avatar
Default paint messed up on hard top
i have a hard top car and i was wondering if anyome elses paint is like bubbling on the top i thought it might have been my car but while at hpe another hard top car had the same issue
Old Mar 26, 2006 | 10:37 AM
273sunsetZ's Avatar
Mine has the exact same problem, I've been meaning to post it, but i keep forgeting. I don't know why it does it. But it really looks bad up close... Does anyone know why its doing this, the paint isn't bubbling, its just the clear coat.
Old Mar 26, 2006 | 03:55 PM
Reject's Avatar
mine too, i'm wanting to paint it again
Old Mar 26, 2006 | 05:06 PM
parbreak's Avatar
Ditto, I assume it's the same problem others are having on the sail panel. The are a LOT of posts about this bubbling problem and it seems to stem from the glue that is used to secure the roof skin. It releases gases and bubbles up through the paint.
Old Mar 26, 2006 | 05:29 PM
Wyoming T/A's Avatar
I Run A Body Shop, Usually If It Is Just The Clear Coat It Might Be Like A Lot Of Gm Vehicles That The Sun Gets To The Clear Coat.are These Car Exposed To Sun A Lot???
Old Mar 26, 2006 | 05:44 PM
99zee's Avatar
There are ALOT of post about this problem. Welcome to the club. If you do a search for roof buubles or sail panel recall, you should get some info. Mine are getting worse, but they didn't show until late. Some have had it fixed for free, some have had to pay half and some have been told "Its not covered". Kind of a crap shoot whether the dealer will fix it or not. Mine is out of warrenty, plus 7 years old so I'm on my own. Good Luck
Old Mar 26, 2006 | 07:11 PM
hardtopz28's Avatar
well i took it to the dealer no recalls so im SOL
Old Mar 26, 2006 | 09:14 PM
daryl2cb@yahoo.com's Avatar
there is a techincal service bulletin about it, I found it, they replaced mine free. I guess the glue used to hold the roof on, septs through the paint
Old Mar 26, 2006 | 09:18 PM
DarkhorSe_SS's Avatar
what bulletin you talkin about?
Old Mar 27, 2006 | 12:07 AM
CULATR's Avatar
yea my bird's sail panel is in need to, im fighting a gm dealer too here the tsb https://ls1tech.com/forums/attachmen...chmentid=30522
Old Mar 27, 2006 | 02:55 PM
99zee's Avatar
Correct. I'm at work and don't have the tsb number here, but can get it tomorrow if no one else post it.
Old Mar 27, 2006 | 04:31 PM
MasterV8's Avatar
I have this problem but on the hood just above the headlamps!
I'll probably get it resprayed sometime as there are a couple of nasty stone chips further up the hood!
Old Mar 27, 2006 | 05:43 PM
pSSycotic's Avatar
its normal on these cars...i have a snake like bubble thing going down themiddle of mine.....gm fucked up....
Old Mar 27, 2006 | 06:53 PM
hardtopz28's Avatar
thanks for the service bulletin im printing out right now to bring to dealer
Old Mar 28, 2006 | 09:02 AM
99zee's Avatar
Mine too. When you see the top without the roof panel you can see where it came from.
Old Apr 18, 2006 | 11:24 PM
LS1T/A4's Avatar
Exclamation
I have a 99 Formula hardtop that has snake bubbles. If I take the TSB to the dealer will they fix it for free or do I have to pay?
Old Apr 19, 2006 | 12:04 AM
CashMoney's Avatar
Good luck everyone I got mine replaced from a dealership 60 miles away (I have three nearby who refused to do it). The GM 800 number helps a little.
Old Apr 19, 2006 | 09:17 PM
KCRickSS's Avatar
I had the same problem. I took the SB to the dealer and he was very cool about it. They fixed it right up for me over 1 year ago. My only problem was the damn body shop there sucked at painting/polishing. It kept glazing over after a week or so and I had to go back 3 times to get it buffed again. Its been good for a while now.
What's weird is that I was the only person who has reported the problem and brought the SB to the dealer by then. This is a large KC dealer, so that was strange.
Old Apr 19, 2006 | 09:58 PM
Payne01SS's Avatar
Depends on the dealership. First place I went to said I'd have to pay. The second place, 10 miles down the road and owned by the same guy who owns the first one, fixed it for free.
Old Apr 19, 2006 | 11:58 PM
67SS&99SS's Avatar
Exactly! My car has the same thing going down the roof, but there is a big dot at the end, so at night when cool air condenses on the roof, it looks like there is a huge question mark on it.
