chrome engine dress-up
Old Mar 27, 2006 | 08:30 PM
Forza13's Avatar
Default chrome engine dress-up
where can i get a good price on chrome engine dress up. mostly caps and covers, and will coil covers fit under my slp STB? if they do, can someone post a pic?
chrome door sills too?
Old Mar 27, 2006 | 11:45 PM
nhra-trans-am's Avatar
Moderator
dynoproauto.com for door sills
Old Mar 28, 2006 | 03:31 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
MBA sold all the caps/covers but are now out of business. Thunder Racing seems to have most of whatever stock they had left. They don't have chrome though - only polished aluminum or anodized colors. I bought the polished aluminum versions from MBA and had them chromed.
Old Mar 28, 2006 | 07:55 AM
Forza13's Avatar
thanks, hey does anybody know if fuel rail covers will fit under a slp STB??? If they do, please post pic.
Old Mar 28, 2006 | 08:18 AM
GotV-8's Avatar
Yes they will.
Old Mar 28, 2006 | 09:44 AM
RollTideTA's Avatar
jegs.com has alot of dress up stuff for f-bods that noone else seems to carry
Old Mar 28, 2006 | 10:34 AM
ulySSes's Avatar
www.thunderracing.com still might have some MBA products in stock. I'd give them a call.
Old Mar 28, 2006 | 10:54 AM
~JOSHUA's Avatar
No they wont. The bar is too low. You will need a BMR or similar height. The SLP will let the FRC's under it, but it is extrmely close. When you rev the engine it will gouge and scratch the hell out of them.
Old Mar 28, 2006 | 11:50 AM
Forza13's Avatar
yeah you're right. I just measured it and there is not enough clearance. I have to get another STB, ****!
unless anybody knows how to add a lil height where STB is bolted?
Old Mar 28, 2006 | 01:15 PM
~JOSHUA's Avatar
If you put 3 or 4 thick washers under the mounts that *might* give you some wiggle room, but then you will have less threads showing to screw the nuts down on.
Honestly, if you have FRC's you don't have the SLP bar.
I was going to do FRC's a year ago, and I didn't feel like getting a new bar so I ended up polishing my whole engine instead. So I know very well how the bar wont fit. It turned out for the better though.
I don't even have the SLP bar anymore...
Old Mar 28, 2006 | 02:35 PM
Forza13's Avatar
yeah, you've got a badass lookin engine
Old Mar 28, 2006 | 03:21 PM
~JOSHUA's Avatar
Thanks. Here's an a photo taken from my helicopter:
Old Mar 28, 2006 | 03:31 PM
Forza13's Avatar
how'd you clean up all your wiring???
Old Mar 28, 2006 | 05:51 PM
~JOSHUA's Avatar
Remove everything that doesn't need to be there. Like the pcv system, factory wire loom, strip the factory injector harness-retape after running the wires thinner and hide the newly wrapped wires under the fuel rails. Relocate the coils under the cowl. You can see a glimpse of the polished coil brackets over each vavlecover under the cowling. -Joshua
