Wiring Question
Old Mar 30, 2006 | 11:00 PM
NexGen's Avatar
Default Wiring Question
Has anyone done the wiring under the strut tower in between the fenderliner mod? I only know one person who has done it before? Anyone know how to do it, how hard it is, or anything?
Old Mar 30, 2006 | 11:14 PM
ncstate98's Avatar
I've done it, and if you cut the hole in the right place you won't need to extend any of the wires. I was clever and used an LT1 fuel line grommet, but I hear that they are extremely difficult to purchase by themself. I think there are writeups floating around for it but I couldn't tell ya since I did mine long ago. If you look in front of the ECU there is a fairly flat area about 2x3 inches where the wires will run nicely. I'll try to get some pics if you need them.
Here is a pic from the wheel well on a friends car that I was working on. If you can imagine this area, you're looking back towards the ECU. I drilled out those 4 smaller holes to make the radius for the grommet, connect the edges with straight cuts and there ya go.
NexGen's Avatar
nobody knows.......
Old Mar 30, 2006 | 11:17 PM
WhiteKnightZ28's Avatar
Tech Resident
As in the !wire mod?
Its been done a million times, heres the link:
https://ls1tech.com/forums/appearance-detailing/173263-completed-wire-mod-tutorial-inside.html
Old Mar 31, 2006 | 12:38 PM
LawmanSS's Avatar
https://ls1tech.com/forums/showthread.php?t=173263
I've done it...followed the link above with no problems...
