Cutting A4 shifter & MBA ball question
Old Apr 3, 2006 | 04:26 PM
SmokeySS's Avatar
Default Cutting A4 shifter & MBA ball question
I searched several times first. I know I have seen a thread in the past where someone has cut their automatic shifter rod so that the top/ball is closer to the console. I'm interested in doing the same. The writeup was something about being careful to only cut the plastic because there is a linkage inside the rod.
I think it would look great with a black MBA ball on top of a shortened stick. So, who has done this?
Also, those who do have a ball shifter for their Automatic, since the stock one has a button which engages the lock in the steering wheel - are there any problems engaging P/N/R/D with them?
__________________
Addition
__________________
Has anyone successfully used a manual/automatic shift ball adapter with a manual MBA ball? I called TR today because they still have a bunch of the manual shift ***** but they don't sell the type made for autos and couldn't give me an answer about whether their manual shift ***** would work with an adapter.
Old Apr 4, 2006 | 11:09 AM
SmokeySS's Avatar
Bumped.
Old Apr 4, 2006 | 12:22 PM
King James's Avatar
Constrictor, a mod over on LS2 is the one that did this.
Old Apr 4, 2006 | 01:25 PM
wickdws6bird's Avatar
I have had mine for nearly a yr now and have yet to have a problem with it not engaging. you just puh the ball down instead of the button.
Old Apr 4, 2006 | 03:59 PM
SmokeySS's Avatar
Was your ball made for an automatic or did you convert a manual one?
Old Apr 4, 2006 | 08:55 PM
it was made for an auto, I also did an manual boot and took the plastic crap out and it makes it look 100x better.
Old Apr 4, 2006 | 09:57 PM
djsanchez2's Avatar
Pics....How-to, and were to source parts, please. I wanted to do that about a year ago but gave up as there is not really much info around on the subject.
Old Apr 4, 2006 | 10:27 PM
Thunder Racing is the only place that has the MBA ***** new, as MBA went out of business a while ago and sold their stock to them. As for the how to I am going to assume you mean the cutting not just the install? Ans same with the pics? So I will let someone else that knows go for that one and post pics if they have done it. But if you just want picks of the **** installed let me know and I'll get some tom if nobody else has by then.
Old Apr 4, 2006 | 11:16 PM
SmokeySS's Avatar
Yeah well like I said in my first post, I want to make sure the manual ball adapter WILL work because TR doesn't sell auto ***** or conversion kits and won't comment if they'd work. Plus they're expensive and I'd be irked if it didn't work.
Sanchez, I'm planning on buying some leather to do the shift boot addition as well. After some searching I got a couple finds.
https://ls1tech.com/forums/showpost....11&postcount=3
I had another one bookmarked from this site that supplied some pictures but I can't find it right now in my favs.
http://www.fadingarrow.com/ShiftBoot.htm
But I want to know about proper cutting of the shift column.
Old Apr 5, 2006 | 05:51 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
Well, he has 158 pages of posts over there - I just went thru 26 with no luck finding it.
Does NE1 have the actual link? I'd like to know about the cutting part also
TIA,
-Jay-
Old Apr 6, 2006 | 02:29 AM
concubine_number_4's Avatar
I'll have a full write up with pictures on how I chopped my shift shaft down(that sounds dirty).
Old Apr 6, 2006 | 02:47 AM
SmokeySS's Avatar
Heyyyy that sounds awesome, minus the innuendo
I was trying to find a complete shifter or just the shaft so I'd have an extra in case I was to do this and screw up.
Old Apr 6, 2006 | 11:13 PM
SmokeySS's Avatar
So we're gonna just avoid page three for a little while and hope someone will reply with the info because I know someone here has cut their shifter. I've seen the pictures somewhere around here.
Old Apr 6, 2006 | 11:54 PM
Unstang's Avatar
The previous owner of my car cut mine 3/4 of on inch, it looks nice. You can PM him on here & see if he can tell you what he did. 99ssleeper is his user name...
Old Apr 7, 2006 | 09:10 AM
https://ls1tech.com/forums/appearance-detailing/484302-chopped-automatic-shifter-manual-shifter-installed.html
