Camaro HID Projector Headlights
#42
Here is another thread and a webshots page about installing projectors in a 98+ Camaro headlight.
https://ls1tech.com/forums/showthrea...ght=camaro+hid
http://community.webshots.com/album/116863233uyEamc
#43
Originally Posted by 2001CamaroGuy
You said you are using TSX Projectors?
Where did you get the cool "cover/housing" the makes everything look nice?
LS1_SS said he had the TSX's.
MosesMcgregor is showing this pic of the 50MM HID Xenon Hella projector and they come with that silver shroud.
#44
Originally Posted by JasonWW
Your mixing the people up.
OHHHHHHHHHHHHH....thanks
#47
How do Hella compare to say OEM Bosch, TSX, etc?
One unique feature is that some projectors have a nice color band at the cutoff point. What this does is create that blue purple flicker you see when the car is coming at you at night. It can have the 4300 white bulb, yet still flicker, twinkle blue. It's very cool. The Bosch E46 and the Honda S2000 projectors are like that. Sometimes you can bend the cutoff shield slightly to increase or decrease that effect.
Here is what a E46 looks like. Notice the color at the cutoff. Check pic at bottom, too.
You can read some of these threads:
http://www.network54.com/Forum/216460/
But I would suggest signing up at:
http://www.hidplanet.com/forums/
You can find lots of info on each type of projector as well as the cuttoff pattern and anything else you need as well.
