DRLs that stay bright with headlights?
I'll double check that when I'm back at work tomorrow.
Cool man thanks, hopefully it really is that easy.
This modification prevents the DRL module from knowing when the headlight switch has been turned on so it doesn't dim the front lights. Unfortunately, it doesn't do anything about the automatic headlights on a Camaro. When the headlights go on automatically the front lights will dim. In order for this mod to work on a Camaro you also have to disable the automatic headlights. The easiest way is to short the two ambient light sensor wires together so that it thinks it's daylight all the time. Normally you would do this someplace close to the sensor but since you will be modifying the DRL connections it might be easier to just short the two wires right at the blue connector for the DRL module. The light green with black wire and the yellow with black wire are right next to each other so you can just crimp on a scotchlock connector to short them together. This is also easily reversible if you want to go back to stock.
I have checked the wiring diagrams fairly thoroughly but I may have missed some side effect of this mod so test everything. Make sure all lights and signals work before you put the dash back together.
