Window tinting help... Bubbles
Old Apr 29, 2006 | 07:17 PM
NemesisLS1's Avatar
Default Window tinting help... Bubbles
Hello.
I just got my windows tinted and the rear hatch has a bunch of little bubbles in it towards the top where all those black dots are. How will i be able to get these to go away?
Using a squeege right now doesnt work. Its only been about 6 hours since i got the windows tinted
Thanks
Justin
Old Apr 29, 2006 | 07:20 PM
klujan13's Avatar
I would take it back to who tinted it for you, unless of course you did it yourself.
Old Apr 29, 2006 | 07:31 PM
Sprayed1998's Avatar
they will go away, sun helps, dont mess with it
Old Apr 29, 2006 | 07:48 PM
NemesisLS1's Avatar
Yeah they told me that it should go away... but i dont know... it started getting worse across the top. Other than that its great... Tinted to 5% cash under the table. So i should just leave it in the sun and hopefully it will go away?
They said i should bring the car back next week to get the sunstrip installed and if the bubbles are still there they would take care of it. Anyways thats the situation...
Old Apr 29, 2006 | 09:41 PM
blown 346's Avatar
When you take it bach have them go over the tint with there heat gun, that will take out the bubbles, and the tint will fill in the matrix dots on the bck window as well, if that is a problem.
Old Apr 29, 2006 | 11:03 PM
NemesisLS1's Avatar
Yeah the matrix dots... thats the problem... Well alrighty then. What if I took a hair dryer to it tomorrow? on low setting...just to see if that might make all the little air spaces go away?
Thanks guys!
Old Apr 29, 2006 | 11:41 PM
WestSide's Avatar
i'd say have a piece of black vinyl put across the window to cover up the matrix dots...unless you want them ground down? Never seen the bubbles go away personally.
Old Apr 30, 2006 | 02:23 AM
blown 346's Avatar
My matrix dots are not visible, the tint stuck to them since the tint installer I used, did the hot air gun and squezzed the air out and made the tint stick.
