Installed new plastic hood (pics)
Old May 13, 2006 | 02:43 PM
WhiteBird00's Avatar
Ungrounded Moderator
Default Installed new plastic hood (pics)
I installed my new WS.6 style composite plastic hood last week. It comes pre-painted and just bolts on in place of the original. The paint match and fit are really good although it takes a little adjusting to get the gaps aligned.
I was amazed to see a 15% increase in highway gas mileage. I had used improved gas mileage as a way of convincing "she who must be obeyed" that it was a good idea to upgrade to ram air. But I never expected my mileage to go from 22 mpg to 26 mpg just from installing a hood.
One thing I noticed that others may be able to help with - the car got hot inside. It seems like there's not as much air coming through the vents (not a good thing in Florida). The raised section of the hood is right in front of the vent intakes and I'm wondering if it's creating a low-pressure area there that cuts down on air flow. There are four holes drilled in the back edge of the hood presumably to allow air to the vents but maybe there should be more.
Have any of you with WS.6 style hoods (either factory or aftermarket) experienced this? How many holes are in your hoods for air flow?
Old May 13, 2006 | 02:51 PM
TUMBLRws6's Avatar
sweet man...how much does that thing weigh???? i dont have ANY holes in my hood...but now i think i might do that lol some heat extractors might do me some good
Old May 13, 2006 | 03:13 PM
2K2WS6TA's Avatar
Stock WS6 hood doesn't have any holes in the back, and that's the cause of your problem, the heated air from the engine bay is coming out thru those holes and is going into the cowl vent, plug the holes and see what happens
Old May 13, 2006 | 03:50 PM
I really don't know how much it weighs but it didn't seem to be significantly lighter than the original hood when I swapped them (not that my arms are much of an accurate scale).
I wondered about that but the problem doesn't seem to be the temperature of the air (it's cold) just the amount flowing through the vents. I had to turn the fan up to high when I normally only use the second position.
Old May 13, 2006 | 04:27 PM
nhra-trans-am's Avatar
Moderator
looks awesome man!
Old May 13, 2006 | 04:39 PM
2K2WS6TA's Avatar
Misunderstood your post, you're asking about volume not temp
I can't really say if the hood makes a difference, its been on there since new, and I have nothing to compare it to
Old May 13, 2006 | 04:52 PM
Dom's Avatar
Dom
Looks good. Where did you get it from?
Old May 13, 2006 | 07:15 PM
Non-sponsor, PM'd you.
Old May 13, 2006 | 08:36 PM
02trns_am's Avatar
could you pm me about it also? Thanks
Old May 13, 2006 | 08:55 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
PM me please
Old May 13, 2006 | 09:10 PM
Mike02Z's Avatar
Do they have SS prepainted hoods as well? If so could you please PM me the company name as well?
Hood looks great!
Old May 13, 2006 | 10:36 PM
1BADTALS1's Avatar
Hmm could you pm me about were youo got it also? please and thank you.
looks good really good
Old May 13, 2006 | 11:27 PM
geo 95 bird's Avatar
me too, thanks
Old May 14, 2006 | 12:27 AM
NxLS1496's Avatar
shoot me a pm on manufacturer too thanks
Old May 14, 2006 | 12:30 AM
FLAWLS1T/A's Avatar
+1 on the Pm's
Old May 14, 2006 | 12:31 AM
Ramshaft's Avatar
is there a problem with the volume of air when you are stoped like at a light? i was just thinking if it does not blow any harder when the car is stoped then i don't think that it would be you hood because if the car is not moving then there is no moving air the cause a low persure problem. i don't just a thought may be it will help
Old May 14, 2006 | 04:55 AM
Mach 5.7's Avatar
Seems like you should be able to say what brand hood it is can't you? But not where you got it from precisely? Moderators? When people search "hood" this thread will pop up but be kind of meaningless in that context (w/out PM'ing you).
anyway - Nice car man :-)
Old May 14, 2006 | 05:34 AM
6LITEREATER's Avatar
Probably not the hood, just an LS1 thing...
I've had two LS1's (a Red 1998 Z and Mystic Teal 1999 T/A) that did the same thing occasionally... Sometimes I would even put it on high and could hear the blower motor blowing like hell but the "doors" inside obviously weren't opening up properly...
Happened on a friend's 2001 NBM Z as well...
Maybe the vacuum line (in the engine bay) that controls (sends vacuum to) the a/c was knocked a little loose during the hood install???
Old May 14, 2006 | 06:24 AM
Viper's Avatar
+1 on the PM
Old May 14, 2006 | 07:03 AM
lovin myls1's Avatar
But a WS hood can help gas milage? Wonder why...
By Brett Foote | 2026-06-04 05:00:17
