Easiest way to remove moldings??
Old May 21, 2006 | 04:48 PM
1nastyss's Avatar
Default Easiest way to remove moldings??
Its summer , so im about to remove my side moldings finally, just looking for the best way to remove them.....
Old May 21, 2006 | 04:57 PM
BlackHawk T/A's Avatar
After trying another method, the one that worked best for me was fishing line. I used a 20 or 25lb tess line I can't remember.
Don't forget to wear gloves...I found out the hard way...
Old May 21, 2006 | 05:56 PM
blackbyrd's Avatar
i had a molding remover tool when i did mine it actually pulled most of the tape up with it which was nice
Old May 21, 2006 | 11:39 PM
nhra-trans-am's Avatar
Moderator
yea fishing line and goo gone to get the adhesive left over
Old May 21, 2006 | 11:51 PM
camaroextra's Avatar
I have done it on a few cars, and i just get a firm grip on one end and pull it off, then use a cleaner to get the glue off
Old May 22, 2006 | 01:06 AM
Ling_650vette's Avatar
Dental floss/fishing line, heat gun, goo gone and possibly some gloves.
Old May 22, 2006 | 06:40 AM
contraststriker's Avatar
what they said about the fishing line, but you can use isopropel alcohol instead of goo be gone if you'd like.
Old May 22, 2006 | 10:33 AM
Mr Incredible's Avatar
I just pulled it off and rolled up the adhesive with my thumb. Then a little wd-40 to clean off the smudges. On part of it I borrowed the old lady's hairdryer to warm it up. That helped some of the adhesive stay with the molding.
Got a blister on my thumb. Had to apply alcohol internally to alleviate the pain.
Old May 22, 2006 | 10:39 AM
cjels1's Avatar
yeah WEAR GLOVES!!! use a hair dryer to heat up the molding then just fish the line thru the back and pull up and down till your done. ALSO! while your down there just take off the TRANSAM decals too!
Old May 22, 2006 | 12:30 PM
99FormulaWs6's Avatar
I just took a pair of Vice grips, and pinched the side molding and rolled it off, a heat gun while I did it would have been better, but live and learn. I tried the fishing line and it kept heating up and breaking. So I got pissed and pulled it off with the pliers, and it worked very well.
