Want to use Menzerna Final, will I need Intensive for this?
This is the top of my rear spoiler, spiderwebs enhanced more than you can see in the sun with my camera flash. What I want to know is will I be better off using IP then FP or can I use just FP?
I have a Porter DA buffer but I'll need more pads when it comes time to polish.
The reason I ask is not because of the cost of buying both, but I really don't want to erode the clearcoat at all if I don't have to. So, will FP do away with this?
![](http://img352.imageshack.us/img352/1691/dsc00606medium0tr.jpg)
It is best to start light and work your way down to the more abrasive stuff if you need it. With the porter cable, it is a slow process for deep scratches and swirls, and you will need multiple attempts for even moderate scratches. It truly is a labor of love that is worth it.
Well I wanna be clear on this because I am reading about the product and it says it is an abrasive compound and will get out 2000 grit sanding. I don't want to be harsher than necessary. So is the single picture not enough to tell? If it's not I will take more pictures.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Based on the pic I would definitely start with IP and a yellow or orange pad. You need to really crank the speed up to 4.5 or 5 to make it work. Don't worry about the clearcoat; GM paint is known for being very hard, so you will be fine.
