So is Zaino still hot?
Old Jun 1, 2006 | 09:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default So is Zaino still hot?
I've never used it, but I'd like to make this 02 Z06 look gooder.
Old Jun 1, 2006 | 10:06 AM
chupr0kabra's Avatar
It's still an excellent sealant. Very durable and (from all accounts) the new Z2Pro seems to have solved the "sterile plastic" look that I didn't care for with Z2. As long as there are no swirls in your paint, it should end up making it look very nice.
-Mike
Old Jun 1, 2006 | 10:21 AM
Mike02Z's Avatar
What he said ^^^ !!
Still great stuff and I still have not tried the ZFX or Z2pro.
Old Jun 1, 2006 | 10:30 AM
Luster's Avatar
I'm old. I've been polishing, waxing, sealing, etc. for 30 years.
Z2 Pro is the best I've ever used. I can't imagine ever going back to anything else. Every time I use I am still amazed....
Old Jun 1, 2006 | 10:39 AM
ZaneO's Avatar
There are tons of great products out there. The key to a great finish is the proper prep work (ie. claying, polishing, etc.).
With that said, Zaino is *my* favorite sealant. Z5 Pro and Z2 Pro produce some very nice results.
Old Jun 1, 2006 | 10:45 AM
Mike02Z's Avatar
You two guys make me want to ditch the rest of my Z5 and Z2 and buy some of the Z5 pro and Z2 pro stuff! I can't imagine my car looking better than it does now using the old stuff.
Old Jun 1, 2006 | 10:46 AM
Luster's Avatar
I saw a big difference between Z2 and Z2 Pro. Haven't tried Z5 Pro, but I've heard great things.....
Old Jun 1, 2006 | 12:28 PM
Raise's Avatar
Like ZaneO said, its all in the prepping of the paint. going thru the prep steps (claying, cleaning, buffing/polishing) is mandatory for a good finish. once u have the prep down, there are quite a lot of good sealants/waxes that will look great and hold up. ive been detailing for a while now, and i prefer either the Zaino process or the Meguiars 3-step process. they both look great and hold up well
Old Jun 1, 2006 | 07:49 PM
2002 Trans Am's Avatar
Haven't used much else, but I also don't find any reason to
Old Jun 1, 2006 | 08:47 PM
kws87's Avatar
I have used lots of other stuff, get some zaino
Old Jun 1, 2006 | 08:48 PM
ProjectCamaro's Avatar
I was a long time Zanio freak but I have recently switched to Meguiers and am just as impressed with the finish.
Like it was said above it's all in the prep work. I washed my car, clay bar'd it, then used Meguiers' three step proccess(swirl remover, polish, wax), and then finished it off with a detail spray. Looks just like my Zanio and so far has lasted just as long. I have nothing but good things to say about Zanio but I can get Meguiers for a lot cheaper and if I'm low and I run to the store to pick more up.
I still use Zanio's "Leather in a Bottle" because the smell is just so good.
Old Jun 1, 2006 | 10:35 PM
_JB_'s Avatar
I like it,
Old Jun 1, 2006 | 11:57 PM
2K2WS6TA's Avatar
Zaino or no, can't really tell
Old Jun 2, 2006 | 04:14 AM
GEARHED's Avatar
I got screwed by using Zaino - did all my prep work (2 days), all layers (3 days for a good cure) then a contest came up for a free paint job.
Even letting the car 'soak' with Tide soapy water on it, the Zaino *still* wouldn't come off enough to make it look dull again!!!!!!!
If I'd just used NXT or Meguires it wouldn't have been as much as a problem getting it to look dull (I've used those and M3 products so I know which hold up best).
Now I can only hope the over lighting will show how badly the TA needs a paint job...Zaino is that good. Still.
Old Jun 2, 2006 | 07:28 AM
Luster's Avatar
Originally Posted by GEARHED
Even letting the car 'soak' with Tide soapy water on it, the Zaino *still* wouldn't come off enough to make it look dull again.. ... Zaino is that good. Still.
I heard that sandpaper will take it off. Good stuff....
Old Jun 2, 2006 | 07:42 AM
Mike02Z's Avatar
Alcohol takes Zaino off.
Old Jun 2, 2006 | 01:14 PM
Z94SLEEPER's Avatar
Question
Hey which Meguiers did you use or still use?
Old Jun 2, 2006 | 01:44 PM
INMY01TA's Avatar
I never liked Zaino.
Old Jun 2, 2006 | 01:53 PM
ZaneO's Avatar
A well known detailing quote..."Find something you like, and use it often."
Old Jun 2, 2006 | 05:21 PM
rubber duck's Avatar
both meguiers and zaino give great results, but for me zaino held its luster quite a bit longer than the meguiers.
By Brett Foote | 2026-06-04 05:00:17
