Applying decals?
Old Jun 2, 2006 | 03:40 PM
SweeTbone's Avatar
Default Applying decals?
I had my ASCD hood painted two weeks ago. I waited a little for the paint to cure. Is there any special prep I need to do to apply the ram air decals? I've been reading about rubbing alcohol and different methods. Will a simple wash, dry then apply work for me? Not like I mind dropping a little more coin on decals if something screws up, I'd just rather it work out the first time. Thanks......
Old Jun 2, 2006 | 05:09 PM
Brian2006's Avatar
If you really wanna be safe, wash with dish washing soap and then claybar the area
Old Jun 2, 2006 | 05:56 PM
RollTideTA's Avatar
rubbing alcohol is your friend... and really all you need to prep the area for adhesion.
Old Jun 2, 2006 | 08:21 PM
Gipraw's Avatar
I always clay bar first, just to make sure there are no surface contaminants on the paint.
Old Jun 3, 2006 | 10:09 AM
Scotty-Z's Avatar
The past two responses are good.
First use a brand new claybar (new to make sure it doesn't have any oils or things that will scrape the paint). After that, wash the area normally and dry it. Then use rubbing alcohol to prep the area and you're ready to go.
Be sure to put up pics when you're done!
