C5 mirrors on a TA?
What is involved in the swap and is there a write-up? What is used to cover the spot where the factory mirrors are located? Any help is appreciated
Vin
interested too
I had to drill through the door and mount them to a custom made bracket inside the door skin. Then, a custom metal piece was fabricated to cover the original mounting spot - with studs welded on the back to bolt it in place. The Y-body wiring was spliced into an f-body harness so it could connect to the control wires inside the door.
You guys /gals are right..I always forget that about the Camaro...
thats why i said it would look
