HID help please someone!
Old Jun 22, 2006 | 03:20 PM
PERFECT Z28's Avatar
Originally Posted by Rollmodel
went to go for a ride this monday night, turned the lights on and only one of em was workin....been working a lot lately so havent touched it since...came home today and they both came on..? any thoughts...something getting wet and causing this? any suggestions would help..
It's problably a loose connection, make sure all you wires have a good clean connection.
It happen to mine when I first put them on. Have had any problems with them in over 2 years.
Old Jun 22, 2006 | 05:16 PM
01RedT/A's Avatar
you ahve to rememebr, t/a headlights move, ALOT. if your wires arent routed perfectly, youll cut one or both (dont ask me how i know). check that first. water could be a problem, but ive had mine for a year now with no water problems whatsoever. make sure you have a good ground, and that you didnt fry your stock wire harness. if non of that helps, switch your bulbs/ballasts (whatevers easiet for you) to try and figure out if its a malfunction (happens alot with aftermarket kits)
Old Jun 24, 2006 | 11:55 PM
MOE_TAWS6's Avatar
Is there a HID kit made for LT1 style Trans ams???
Old Jun 25, 2006 | 11:41 AM
JasonWW's Avatar
Nope, no kits. You have to make it yourself. Since the LT1 light area doesn't have room for 2 bulbs, you can either put in a low beam projector and find another location for the high beams, install a bi-xenon projector for both high and low beam or just get a conversion housing and install an HID bulb in it. Your most likely going to have to cut some of the metal out behind the light to get enough depth.
Here are some LT1 links.
https://ls1tech.com/forums/appearance-detailing/523486-custom-lt1-headlights.html
Scroll down to the red LT1.
https://ls1tech.com/forums/showthrea...42#post3596142
GrnDragons car.
http://www.cardomain.com/ride/2146367/1
