gauge bezel
I have both an aluminum version and stainless steel. I went to the trouble of tearing out the gauge surround only to find that to install the overlay you have to remove the back portion of the surround from the clear plastic front section. That thing is bonded/glued as if it had to survive a nuclear detonation
I still have not figured out how to remove it short of cutting it off - only problem is - the way it's made I can't see how to do that without totally destroying the entire part. So I put the surround back in and the overlays are just setting there...
If you have what I think you might, I'm not sure it will work right with a Firebird cluster.
https://ls1tech.com/forums/appearance-detailing/420782-gauge-cluster-lens-bezel-do-they-come-apart.html
I can get them through the dealer at around $40.00
I too have one just sitting in my garage... for the exact same reasons Trending Topics
