How do door panals come apart?
Old Jun 19, 2006 | 10:18 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default How do door panals come apart? EDIT- PICS INSIDE of new panals
I have 2 days off so Im working on my INT some, and tonight I tried to tape off my door panals to repaint them and it didn't work out too good, to many complex corners and tight squeezs. I have the products that work good for this stuff, but I need to take the door panals apart, meaning I need to take the door grab off, and the vinal seperated, and the other stuff all seperate, how do you do that?
Old Jun 19, 2006 | 11:49 PM
jmilz28's Avatar
Remove center screw behind door handle
slide off bezel around door handle
There should only be 3 more screws that hold in the pull:
1 on the front of the pull and 2 on the bottom
Then pop up on the door pull and it will slide right off
Old Jun 20, 2006 | 12:11 AM
Sgt. Spuds's Avatar
I know how to get it off the door, I need to get it apart. but thanks anyways man!
Old Jun 20, 2006 | 02:39 AM
00hawk120's Avatar
you will have to grind the plastic washers off to get it apart. i did and had to use some screws to put it back togeather again.
Old Jun 20, 2006 | 08:17 AM
contraststriker's Avatar
I painted mine without taking them apart, it isn't bad.
Old Jun 20, 2006 | 03:16 PM
Sgt. Spuds's Avatar
Picture removed, look down a few posts.
Old Jun 20, 2006 | 03:20 PM
Sgt. Spuds's Avatar
I may try to do the passangerside one without taking it apart, it was a BITCH to get apart, and now I still have to attatch the door pull. The white paint is the same as the black paint on the door pull, duplicolor vinal/plasitc paint. They say you can use it on carpet and upholstory too, as well as seats. I may try and use it on my carpeting, see how it holds up, before I spend 200 bucks on new carpet.
Old Jun 20, 2006 | 03:49 PM
phantomzer0's Avatar
You gotta go back and tighten up that vinyl, if thats what it is. There are alot of wrinkles. I'm sure you noticed that though,
Old Jun 20, 2006 | 03:51 PM
Sgt. Spuds's Avatar
No more wrinkles than stock, actually, it is stock
Old Jun 20, 2006 | 04:16 PM
What is that from then? Is that from an anniversary car? I didn't know they gave white door panels with black leather?
Old Jun 20, 2006 | 07:08 PM
Sgt. Spuds's Avatar
Its tan, under the paint
Old Jun 20, 2006 | 07:11 PM
Luna's Avatar
damn spuds, ***** raw
Old Jun 20, 2006 | 07:22 PM
Sgt. Spuds's Avatar
yea I am going to avoid taking the door panal on the otherside apart at all costs. The panal doesn't fit back together the way it used to. I might actually replace this one and start over again. I need to start with the black, THEN the white, and that will allow me too not have to dissasemble it...
Old Jun 20, 2006 | 09:25 PM
Sgt. Spuds's Avatar
does raw mean good or bad?
Old Jun 20, 2006 | 09:27 PM
Luna's Avatar
lol, it looks pretty good
Old Jun 20, 2006 | 11:32 PM
| Powered by Satan |'s Avatar
yeah, not to bad spuds
Old Jun 20, 2006 | 11:45 PM
VIP1's Avatar
Copy & Paste Moderator
Here is the write-up I followed when I took apart my door panels:
http://www.lastofthebreed.com/Instal.../DoorPanel.htm
I deviated a bit though. I used 2-part LockTite plastic epoxy to re-attach the panel instead of melting/screwing anything. Just mix it up and put a blob over each cut plastic peg/mount (and keep some pressure on the panels until the epoxy hardens).
Old Jun 21, 2006 | 12:02 AM
Sgt. Spuds's Avatar
Luna gave me that link and I followed it to a T, I used hot glue to hold the panal back together, and I think I should have used something a bit better... Passangerside ( next day off lol ) is gonna get done while still together if at ALL possible. I tried it on the drivesride, but I had rushed through the masking to try and get it done before dark, and that screwd me up. I think I should do the black, then once that has hardend for atleast a hour, go back out and do the black vinal ( soft door pull ) then let that dry for a hour, then tape it all off really good with some blue tape ( got it already ) and then go to town on the white.
I also am going to repaint that white triangle peice infront of the mirror black. The white was a really ricy idea up there.
