View Poll Results: where to mount 3 guages
triple pillar pod
44
72.13%
3 center ac vents
14
22.95%
other... please explain
3
4.92%
Voters: 61. You may not vote on this poll
Guage mounting....
Old Jul 4, 2006 | 10:59 PM
navymitch12's Avatar
here is mine...i like it a lot, little hard to see some of the fuel pressure from where i sit but i can see the part i need to see.....
Old Jul 5, 2006 | 08:59 AM
bowtieman81's Avatar
Originally Posted by Lethal_Ws6
I really Like Frost's setup, But i have the triple pod in my A-Pillar With Autometer Phantom guages (Nitrous,Fuel psi) And the Dynojet Wideband .. With all Red Caps.. Looks factory with the red lights .. and a clean setup.. you should run it ..
Can you elaborate a little more. What are the red caps you speak of? Do you have any pics?
Old Jul 5, 2006 | 01:01 PM
NA$TY-TA's Avatar
Im a little Bias on mine......
Kyle
Old Jul 5, 2006 | 02:04 PM
i think he means the red caps over the lights that make them red
Old Jul 21, 2006 | 02:03 AM
6LITEREATER's Avatar
I personally HATE three pod pillars... the third is SO high and close to your head/face...
I voted for OTHER... here's my suggestion:
2 on the pillar and one here (like mine):
I also have ONE in the pillar:
To be honest... I don't like dual pod pillars either so if you HAVE to have three I would put ONE on the a-pillar and then do two like this:
It's owned by blaSSt if you want to do a search for the how...
Old Jul 21, 2006 | 02:54 AM
chewy99ws6's Avatar
I would go triple pillar.
Old Jul 21, 2006 | 06:37 AM
NA$TY-TA's Avatar
Thats way to low for me..... u totally have to take your eye off the road to even look at it... thats the point withthe 3 pod pillar... its right there....
Kyle
Old Jul 21, 2006 | 10:21 AM
Photochop's Avatar
I like the idea of using the autometer mustang style dual gauge pod that replaces the clock on those cars and trimming the bottom edge to fit your dash. Install it just in front of the defroster vent and run the cables right into that to hide them. I've seen a couple of posts on here with them and they look good. I'd run your fuel pressure and wideband up there and stick the boost down in the center a/c vent.
Old Jul 21, 2006 | 11:11 AM
Sgt. Spuds's Avatar
Shirley Temple Drinker
3 piller pod, and THEN one in the far left ac vent
Old Jul 21, 2006 | 11:57 AM
Kyle
That's why I put the nitrous there, no one else can see it and I am only looking at it when I open the bottle (which is the switch right next to it) .
Old Jul 21, 2006 | 12:49 PM
BlackBirdWs6Zzz's Avatar
Originally Posted by trtturbo
My train of thought is this. If you see the pod gauges the easiest, then put the most important there and vis-a-versa. Maybe wideband in the vent and fuel pressure and boost in the a-pillar. Just my opinion
this sounds like the best idea. Your not going to be staring at your o2 gauage all day, you want to keep an really close eye on the boost and fuel pressure.
but I had my gauges in the 3 vents. It looks BA too
Old Sep 21, 2006 | 12:19 PM
  #32
onesicws6's Avatar
Does any company make a triple pillar for a non t top f body? Ive only seen them for t tops only, was wanting to go with 3 but i think ill have to go with 2. Anyone ever seen a triple anywhere?
Old Sep 21, 2006 | 04:21 PM
  #33
black_z's Avatar
I like the AC vents. But I have a lowly camaro.
Old Dec 16, 2006 | 12:47 AM
  #34
tbird31's Avatar
i'd do a double gauge pod...then one in the far left, center AC...just because 3 on the pillar is alot and i like the ac vents too...they don't all need to be together unless you want them to...
Old Dec 16, 2006 | 01:26 AM
  #35
onebadblackz's Avatar
Originally Posted by FormulaFire
I had a dual pillar in my last car w/ one guage in the left ac vent. And in my current car I have the tripple pillar. I prefer the triple pillar personally.
what gauges are those and were can I get them?
Old Dec 16, 2006 | 01:29 AM
  #36
Originally Posted by Frost
what gauges are those were can I get em
Old Jan 13, 2007 | 12:33 AM
  #37
No Juice's Avatar
Has anyone tried the Zeitronix set up? It has Boost, AFR, EGT, data logging, and one user input that could be used for fuel pressure
Old Jan 13, 2007 | 09:35 AM
  #38
Superman09's Avatar
LS1Tech Sponsor
thread from the dead... However, FWIW, I got my guages done! Here are some pics....
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 13, 2007 | 05:37 PM
  #39
No Juice's Avatar
[QUOTE=Superman09]thread from the dead... However, FWIW, I got my guages done! Here are some pics....
QUOTE]
Did you do an AFR guage?
Old Jan 13, 2007 | 05:50 PM
  #40
Nice ! Congrats !
