do i need to blend the fenders
just wonderin what to expect.....
ohh and i believe the code for bright rally red is 81U is this correct... i would look on the door but all the codes are gone!!!!! i suppose i can just use the search feature for that
The paint store will be mixing the paint based on the formula of 8IU. There is alot of room for error, especially on reds. Depending on the brand of paint that you are buying, there could be some variances for the color listed in the computer at the store too...Meaning you don't really know how close the match is untill you spray out some test cards.
Use test cards, spray them with color & clear, let them dry, campare the color in natural sun light. If you are going to a different color later, you should get it close w/out blending for now.
