New Gauges/LEDS in my Trans Am-Pics
Old 08-12-2006 | 10:22 AM
TORCHD 02 TA's Avatar
i want the led for the map lights and the dome light.. where can i find those at? what are the part numbers?
Old 08-13-2006 | 04:52 PM
_JB_'s Avatar
Originally Posted by LS1obsession
I checked Sylvania's bulb guide and you are correct. There is a difference. I just assumed they were the same . Here is the list for each year:
Camaro guys and anyone else who needs to look up a bulb part number here is the website:
http://www.sylvania.com/ConsumerProd...lacementGuide/
Don't trust that site too much, I bought some LEDs for my reverse lights, but they list the wrong bulbs!
Old 08-13-2006 | 04:55 PM
_JB_'s Avatar
Originally Posted by SeriousPWRTRIP
I ran outside and got some pics of them as well just to show you guys what I'm talking about. This is what I see when i look up at the driver's side map light in the rear view mirror. Passenger side is the same type of bulb. I believe its a 194.
I looked at the back dome light and it is a festoon dome with the metal wire on the end. I see what you were saying about bending the prongs to get it to fit though, so that shouldnt be a problem.
Yes, those are the 194 bulbs. According to https://ls1tech.com/forums/showpost....80&postcount=2, 02 got the revised mirror (I do), but I guess some of the 01s also got it.
Old 08-13-2006 | 05:12 PM
_JB_'s Avatar
What lights did you have to change to leds for the cluster? I want to put a white face guage in, and also change the lights to red leds.
Old 08-13-2006 | 05:18 PM
yep i went out side jsut now to look at my 02 ta.. they are the same pics as you jsut posted...
so yea my map are short.. and the dome light is like the festoon.. now what????
Old 08-13-2006 | 05:22 PM
_JB_'s Avatar
Map lights=WLED-x6 LED Wedge Base Bulbs (http://www.superbrightleds.com/mini-wedge.html)
Dome light=44 x 10 mm Festoon base with 9 LEDs (http://www.superbrightleds.com/festoon.html)
Old 08-13-2006 | 06:20 PM
LS1obsession's Avatar
The bulbs are 194's, the same for your map lights and glove box. I would go with at least 6 LEDS. The bulbs I put in contained 4 LEDS and it was definately not bright enough.
You will need to order 5 bulbs. Here is a pic that shows which ones to replace:
Old 08-13-2006 | 07:01 PM
c0ncEpT's Avatar
Im diggin the cluster ! but dont you wish the damn bird would light up!!!!! that would be so bad ***
Old 08-13-2006 | 09:04 PM
PedroDePackas's Avatar
I've got a 2000 T/A and it uses the 4410 Festoons for both the dome and map lights. Superbrihtleds.com has them for half the price of the Velocity LEDs place. I'm thinking of picking up a set of red ones. Someone else here had a picture of all red lighting inside his bird, it looked pretty sweet.
Old 08-13-2006 | 09:31 PM
huh??? what did you say lol
Old 08-13-2006 | 09:50 PM
Keep in mind you get what you pay for.
Old 08-13-2006 | 09:57 PM
  #32
SeriousPWRTRIP's Avatar
I ordered several different 194s to test in my map lights, since 194 is a common bulb anyway. I ordered all of my bulbs from Velocity LED. I'm still awaiting their arrival. I'll let ya'll know how bright they are and which bulbs worked best once I get them in.
Old 08-13-2006 | 10:01 PM
  #33
i just bought the festoon 214-2 with the 9 led, now i need to buy the 194 HIGH POWER LEDs.. good luck with that, jsut go white and be done with it
Old 08-13-2006 | 10:15 PM
  #34
They're all white to match my new HIDs. I just ordered a couple different LED set ups. Going to try the inverted cone and the 6 super LED bulbs. I figure if one doesn't fit or isn't bright enough, at least I have an immediate plan to fall back on.
Old 08-13-2006 | 10:45 PM
  #35
SSilverSSurfer's Avatar
your car is over heating, you temp gauge is almost in the red, lol, looks good tho
Old 08-14-2006 | 08:32 AM
  #36
_JB_'s Avatar
Do I have to get some sort of "clip" for the leds to hold into the cluster?
Old 08-14-2006 | 08:35 AM
  #37
_JB_'s Avatar
The site says those High Power LEDs are almost as bright as the wled-x6 lights. I would get the wled-x6 lights.
And for anyone wondering if they should put the wled-x5 bulbs into the mirror, my suggestion is NO. They produce maybe 75% of the light as the wled-x6 leds do.
Old 08-14-2006 | 01:27 PM
  #38
well i guess it is too late. i already bought all the lights. i will snap some b4 and after pics..
thanks
EDIT: hey Jeff, nice to meet you, i jsut got a PM from Crawlinws6 i guess i will be meeting you in about a month
My name is Jonas
Old 08-14-2006 | 01:54 PM
  #39
No. Use a pair of pliers and twist out the "holders". Pull out the stock bulbs and put the in 194's. Twist the "holders" back in with pliers and you are done. Keep in mind that if they dont' light up to pull out the bulbs and turn them 180 degrees.
Old 08-14-2006 | 02:44 PM
  #40
RoastEmSS's Avatar
i just put red leds from ledgauges.com, sorry for the pic hugeness
Quick Reply: New Gauges/LEDS in my Trans Am-Pics
