wax question
Old Aug 9, 2006 | 01:19 PM
transam_089's Avatar
Default wax question
i just got my first car and im new to his whole mod and detail thing
i was wondering how often should i wax my car
and after i wax it does it matter if i just wash it ever week?
Old Aug 9, 2006 | 01:27 PM
99zee's Avatar
Is the car new or used, condition of the paint and color, does it stay outside or inside? Depending on the condition of the paint, it might need to be washed and then "clayed" to clean the paint and then apply the wax or polish. In between the times you polish/wax, a good wash followed by some detail spray works great. As for products there are alot out there. I have used Tropi-Care, Zaino, Mequires and Mothers all will good results. Also sent you a PM.
Old Aug 10, 2006 | 11:54 AM
Default thx man
you said between the times you polish/wax clean the car and use a spray detail
do you mean like weekly?
or is it like after you wash your car u spray teh spray detail then u wax it?
Old Aug 10, 2006 | 12:11 PM
2001somws.6's Avatar
I wash the car once a week. Also a quick detailer with a microfiber towel works wonders. Just after you wash and dry.
I only use meguires or mothers stuff.
Your first full detail should wash claying at the same time. Dry. Then a cleaner wax then a wax. orbitals are great for all this. Saves time.
Old Aug 11, 2006 | 03:56 PM
99zee's Avatar
After every wash, I use the detail spray. Brings back that fresh polished look and feel.
Old Aug 11, 2006 | 05:51 PM
NightWindDriftr's Avatar
If your car is a DD, a wash every week or two is fine. A wax, depending on your environment, should be about once a month for over-the-counter waxes. Note that if your washing isn't mild enough, you will strip your wax. Even a mild wash will put a bit of wear on your wax, hence the relatively "frequent" waxing I suggested (especially if you wash your car 4 times a month). Adjusting your washing/waxing schedule accordingly will give your the best results for your particular car!
