Signalwave Sequential Lights
Old Jul 30, 2007 | 07:34 PM
Havok2's Avatar
ill try when i put my lt1 tails
Old Jul 30, 2007 | 08:00 PM
Kev98Ta's Avatar
With Tbones kit- There is NO modifing anything! All 3 lights sequence, and also sequence when the brake is applied. He does recommend switching the outer most bulb for a bigger size (dont remember the number) so it illuminates brighter during daylight hours. But again there is no cutting or dremeling nething... Other than the wires when you splice.
Here is a quick clip of his kit on my car, that ive had for over 4 years w/ no problems. It starts at about a minute into the vid. http://www.fquick.com/videos/viewvideo.php?id=1656
Originally Posted by 99'CajunFirehawk157
I placed an order thru his website and have not heard dick in almost two weeks...I am concerened he is shut down, anyone know t-bone?
Tbone is a LONG time member over at Fbody.com. Try finding him there...
Old Jul 30, 2007 | 08:09 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
How does he reccommend installing a larger bulb without changing the socket? The factory socket is sized very small as the bulb is a #194 if I'm not mistaken. I don't know of any bulbs the same size as the others but with a 194 base.
At the beginning of your vid I was thinking 'holy ****, look at the smoke - boy does that need a tune' then I noticed it was taken in winter
If you use an electronic HD Flasher the lights will sequence more pronounced instead of the smooth wave look (unless that's how you like it) plus the outer bulb (of whatever size) will light for more than a few milliseconds...
-Jay-
Old Jul 30, 2007 | 08:32 PM
Kev98Ta's Avatar
Alright, now you just made me pull my light panel off! I tried to find the numbers for the bulbs, but there were none. I might have the instructions somewhere where he gives the number. Trust me though, it is a larger bulb than the stock 194, in the factory socket. And it works...
Yeah shes had a tune. It was about 19 degrees out when i took that vid.
-Jay-
I'm using an electronic flasher. Theres a speed dial on his board that you can play with to get the desired effect youre looking for. If you slow it down you can get the pronounced look, but yeah, i like the smooth wave like flow.
I'd be more than happy to send you pics of the back of my panels sometime, so you can see for yourself. Shoot me a Pm me if ya want. -Kevin
Old Aug 2, 2007 | 12:45 PM
99'CajunFirehawk157's Avatar
FYI-Thanks for the help, I found him!! ,So I talked to Jason, he is out of units and in school, he does not seem to want to do anymore until then, his website is on hold, if you got one you may be one of the lucky ones? Anyone want to sell a used one?
Old Aug 2, 2007 | 04:08 PM
killerbeez's Avatar
so where can i see an lt1 camaro tail do this?
Old Aug 2, 2007 | 10:57 PM
_JB_'s Avatar
You will not have to do any modification to the tail lights if you don't want the stock look. If you swap out the 194 bulb for a bigger one without changing the socket, you will loose your parking lights. So instead of having three parking lights you will have two. You will need a dual filament bulb to keep the stock look.
Old Aug 7, 2007 | 10:27 PM
Again I ask: Anyone want to sell a used one? (will pay$)
Old Aug 8, 2007 | 12:14 AM
michaelg589's Avatar
I would like to do sequential tail lights. However they are not legal in NJ and I would much rather just have some LEDs back there.
Old Aug 8, 2007 | 01:01 AM
SStolen's Avatar
I'll be the rebel. I hate them. If they came on sequentially at first when the brake was supplied and then stayed on that would look okay. I don't like how they keep starting over... and over... and over.
Old Aug 8, 2007 | 01:13 AM
OiBoyBirdy's Avatar
isnt that the four ways or no? i thought it was
Old Aug 8, 2007 | 12:27 PM
  #32
_JB_'s Avatar
They only sequence once and then stay on as long as the brake is held. The only time they, "start over and over" is when the turn signals are on.
Old Aug 8, 2007 | 05:22 PM
  #33
LILWS6's Avatar
i want them who makes them? or hook me up with some instructions how to build this kit
Old Aug 8, 2007 | 05:40 PM
  #34
rocketman442's Avatar
I've had sequentials on my caprice for years, love em and get tons of compliments. I didnt know anyone made a kit for a ta though.
Old Aug 11, 2007 | 10:24 AM
  #35
killerbeez's Avatar
i love these, I am determined to get a good set for a camaro, I saw one of the new body style mustangs with them and it was off the hook! of course their tails are three square side by side boxes to begin with already.....
Old Aug 11, 2007 | 10:44 AM
  #36
MikeSomething's Avatar
I'm really starting to hate this state!
Old Aug 11, 2007 | 10:48 AM
  #37
blitzed96's Avatar
Type in this item number on ebay and check them out. 260148197577
Old Aug 11, 2007 | 10:51 AM
  #38
killerbeez's Avatar
I wonder if this kit would work if i put lt1 tails in my ls1 car. Anyone know? how hard is it to put lt1 tails in an ls1?
Old Aug 11, 2007 | 10:56 AM
  #39
blitzed96's Avatar
I'm pretty sure they go right in.
Old Aug 11, 2007 | 11:15 AM
  #40
T-bone says the other kits out there are crapola, FWIW.
But since he isnt making them I dont see what choice we would have??
