Signalwave Sequential Lights
Old Aug 11, 2007 | 12:27 PM
  #41
justmetk11's Avatar
im looking forward to a video blackhawk
Old Aug 11, 2007 | 08:50 PM
  #42
LILWS6's Avatar
how much on average does a good kit cost?
Old Aug 11, 2007 | 09:57 PM
  #43
_JB_'s Avatar
Maybe look it up.
Old Aug 11, 2007 | 10:23 PM
  #44
99'CajunFirehawk157's Avatar
avg $75-100.
Old Mar 15, 2012 | 11:11 PM
  #45
99firehawk's Avatar
Hey all, I realize this thread is like over 4 years old but anyone know where else can i find these?
I already have a kit installed and the timing adjuster snapped off the board so it no longer works properly. =(
Old Mar 16, 2012 | 12:21 AM
  #46
If you look thru this thread you can see where I was looking for one too, well I found one and then another...I paid $125 for the second unit as a backup, I never could get the timing adjuster to adjust, but I never did mod the outer bulbs, mine only has one speed, what am I doing wrong?
http://www.youtube.com/watch?v=SIbEunZU0kI
Old Mar 16, 2012 | 12:08 PM
  #47
PontiacFan's Avatar
I don't see anything wrong with that.
Nothing wrong with the timing either.
Sure the outside bulbs are single filament, but they still do what they're supposed to.
Looks good man, ...,
Do ya think it may be the amp draw thru the board/timer that may be altering it so you can't adjust the timing?
(Because of the single filament bulbs.)
Old Mar 17, 2012 | 06:51 PM
  #48
99firehawk's Avatar
Its been like 4-6 years since i adjusted the board, but from what i recall the adjuster didn't make a huge difference, but it did change the timing to sync with the type of flasher that i put in. The flasher (ticker) thats under the dash is what adjusts the speed, from there I think the adjuster just makes it sync to the flasher's delay. Clear as mud?
If you change the flasher under the dash then you will notice a more significant difference in speed.
Your set up however is set up properly by the looks of the vid.
Want to sell you spare sequential board to me?
