Removing the FACTORY 3pc Spoiler
Thanks
The middle piece is just double sided tape, fishing line/goo gone will get it off. and im not sure but the side two are just bolted in there and im assuming the bolts should be somewhere around where your spare tire well is
so no more ugly 3 piece for me. so how do you plan on getting rid of the holes in the quarter panels?
here it doesnt look so bad
but from the back
Thats actually just a chop though, my car has the chrome SS 10 spokes but i wanted to see how it would look with painted black ones. it was the only picture i had readily available.
mike02z, check out the mecham spoiler.
its the same as the SS spoiler, minus the middle supports but has the led brake light like the newer one.
1) open rear hatch
2) pull the plastic liner off of the top of the hatch(inside part)
3) this will give you access to the middle piece, there are two nuts on each side, you cant miss them.
4) unscrew them and the middle piece will come right off
5) for the two side pieces there is three nuts on each side
(which really pisses me off cause now i have 3 holes to fill) go ahead and unscrews them and you good to go. and like i said before the middle piece is double sided taped to the stock spoiler.
