Gauge Lights
Old Sep 29, 2006 | 01:02 AM
The Black Pearl's Avatar
Default Gauge Lights
Well I got my red gauge lights today from www.ledgauges.com and I am very very happy! They are bright and look amazing.. I also got the HVAC and headlight switch kit.. I ran into a little of trouble with the headlight kit so I havent finished it yet.. But here are the pictures of my gauges and HVAC..
Nathan I can get better pictures of the HVAC if you needed a better one....
Old Sep 29, 2006 | 01:36 AM
Z28-CTYHNTR's Avatar
looks killer man, makes me want to invest in a set for my HVAC and gauges.
Old Sep 29, 2006 | 01:37 AM
BayAreaSS's Avatar
Looks good
Old Sep 29, 2006 | 11:14 AM
Thanks.. I really love the look.. Now I just need to get that headlight LED in..
Old Sep 29, 2006 | 11:22 AM
cooltc2004's Avatar
In my opinon, Red is for Pontiacs (always has), but if YOU like it, then thats all that matters.
It still looks great though.
Old Sep 29, 2006 | 12:36 PM
LS1obsession's Avatar
How many leds are there is each bulb? Those look really bright.
Old Sep 29, 2006 | 12:50 PM
For the gauges? Its hard to tell.. I have never see the bulbs that www.ledgauges.com have before.. Maybe there are 4 or something.. Im totally not sure..
Old Sep 29, 2006 | 01:34 PM
Which leds do you have for the gauges?
Old Sep 29, 2006 | 01:41 PM
TORCHD 02 TA's Avatar
Off Topic, can you believe that one of my 194's in the map light went out already! i emailed v-led see what they do!
Old Sep 29, 2006 | 01:51 PM
XtinctZ28's Avatar
Rehab is for quitters...
Try this link for good info on the headlight switch LED. It is simple but seeing it done first helped me alot.
http://www.keliente.com/LED.htm
I did the same kit with my car and it looks great, the headlight switch LED is the dimmest of them all, it could stand to be a little brighter in my opinion.
If you have any questions ask Nathan, he will help you out right away
Old Sep 29, 2006 | 02:02 PM
Yeah I did use that site and still cant get it. I suck with the solder ****! I cant get them to stick together..
Old Sep 29, 2006 | 02:15 PM
XtinctZ28's Avatar
Where are you from? I'll help you if you are close. Try scuffing the small contact ponits on the switch before soldering.
I think I am going to use my extra HVAC LED in place of the small one for the HL switch and see if that brightens it up.
Old Sep 29, 2006 | 02:22 PM
I live in Indiana.. But that reminds me that I have an extra HVAC LED maybe i can put that in there and have better luck.. (Cross My Fingers)
I got 2 headlight leds and i broke one.. But Now I might just try the extra HVAC or see if I can get some bigger leds to work.. (I have some around here)
Old Sep 29, 2006 | 03:04 PM
Brian2006's Avatar
Haha both of yall got that link from me
Try the 194 bulb guys and let me know how it helps before I do mine next weekend
Old Sep 29, 2006 | 03:41 PM
XtinctZ28's Avatar
Hell yes I did. Thanks again.
Old Sep 29, 2006 | 06:21 PM
SSmokeDaGT's Avatar
Does anyone have nathans screename cause I HAVE to order some... I just dont use paypal.. If u see this Nathan PM me please.. By the way looks GREAT i want mine to look the same..
Old Sep 29, 2006 | 08:14 PM
XtinctZ28's Avatar
Nathan goes by LS1_SS. Great guy, very helpful.
Old Sep 30, 2006 | 12:30 PM
Well I tried to solder the extra HVAC light to it and again couldnt get the solder to stick to the thing.. I even scuffed it up.. My solder gun is one of those "Cold Heat" ones so maybe thats the reason its so hard.. You have to get it on there just right or it wont even heat up and then any slight movement it cools off again..
Old Sep 30, 2006 | 01:50 PM
I did it.. I went out to walmart and bought a different solder iron and went at it. I soldered the extra HVAC bulb up to it and well its still light out but from what I could tell it looks amazing!
Old Sep 30, 2006 | 02:48 PM
XtinctZ28's Avatar
Glad you got it done! I went ahead and switched the LED's out. I used the extra HVAC LED as well and it made all the difference in the world. Probably 2 or 3 times as bright as the smaller LED.
