Intake Modification
Old Oct 8, 2006 | 09:28 PM
the_merv's Avatar
Veteran: Air Force
Default Intake Modification
I figured I would throw this in here also..
This is a LS1 Air Box on a LT1 Car. I had to cut the hole in the Hood, but when the Cowl goes on it, you won't be able to tell. Notice where I blocked off the silencers on this setup. I finally broke over 110MPH with this, and that was with a 2.15 60'.
I know it needs a paint job, and it doesn't have the Engine, but you get the idea..
Old Oct 8, 2006 | 09:39 PM
rdeterman's Avatar
thats interesting
Old Oct 8, 2006 | 09:40 PM
the_merv's Avatar
Veteran: Air Force
Yea, something different..
I'll put pics up when it's all together.
Old Oct 8, 2006 | 09:44 PM
Tainted's Avatar
instead of that fugly stock airbox, you should get an mti clear lid that would look cool
Old Oct 8, 2006 | 10:09 PM
the_merv's Avatar
Veteran: Air Force
Right now all funding is going toward re-building the new LT1..
Old Oct 8, 2006 | 10:30 PM
DroppedM6Z's Avatar
......wow. I was told the MAF wires wouldnt not reach, do you have plans for this? Or was i told wrong
Old Oct 8, 2006 | 10:33 PM
zo6vette037's Avatar
Good Idea and I think it would look better if you pulled off the stickers and painted it black... just until you get the hood.
Old Oct 8, 2006 | 10:40 PM
luckyou03's Avatar
thats a slight modification
Old Oct 8, 2006 | 11:15 PM
the_merv's Avatar
Veteran: Air Force
They do reach, just barely. The one that needs to be extended is the Air Temp. Sensor. This was running and fully functional, I had it for about 2 days until the Engine went.
Old Oct 8, 2006 | 11:20 PM
~JOSHUA's Avatar
wow.
Once the car's running, make sure you at least get a clear lid when it's time to cruise.
You do know that you'll have to explain that mod to every car guy that sees it. So.... what made you cut a hole in your hood again?
Old Oct 8, 2006 | 11:28 PM
the_merv's Avatar
Veteran: Air Force
That was the only way to fit it under there. I heard of a guy that got it to fit under a LT1 Hood, and from what I did and what I measured, there was no way...
It looks interesting now, but once it gets a Cowl, no one will tell. It got me trapping over 110mph in the 1/4, and the car was still cold. I can see it hitting 12.6's, and that's still stock Heads and Stall, with street Tires.
I think my AC mod is just as interesting as well, it's in a thread here somewhere. That's tomorrow's project.
Old Nov 7, 2006 | 04:23 PM
PERFECT Z28's Avatar
Any updates?
