Sponsored by: DashLynx
? about swapping antennaes from a formy and camaro
Old 10-21-2006, 08:31 PM
00 Freak's Avatar
Default ? about swapping antennaes from a formy and camaro
My camaro doesn't have the pwr antenna. My wife wants to get rid of the antenna on the camaro so i was thinking of swapping them out. Less weight on the formy(race car). Is this possible if so how difficult.
Old 10-22-2006, 08:09 AM
BitViper's Avatar
I would think hey would be a direct swap...but having never done it...i dunno!
Old 10-22-2006, 07:49 PM
Snuffles's Avatar
It's a direct swap.
You'll have to keep the stock rubber bushing thingy that sits between the atenna and the body.
I had to bend the power antenna bracket to mount it, nothing a small pair of pliers won't fix.
Also, you have to drill a hole for the drain tube. (You'll also need some extra tubing to extend tubing on the power atenna.)
I forget the ID of the tubing but it should be in the write-ups.
Then some wiring and you're set.
The hardest part is running the damn signal wire.
So this is very easy mod.
https://ls1tech.com/forums/appearance-detailing/11189-what-other-parts-do-i-need-power-antenna-mod.html
Old 10-23-2006, 06:09 PM
00 Freak's Avatar
My formula has the pwr antenna and my camaro doesn't. So I could just swap everything over right?
Old 10-23-2006, 06:12 PM
6LITEREATER's Avatar
Yup .
02SS0384's Avatar
They are a direct swap. Actually if you look in the Camaro parts catalog there is a power antenna listed.
Quick Reply: ? about swapping antennaes from a formy and camaro
