Painted Interiors
I have the grey interior and would love to have it black.
To see what the interior of my car looks like right now check out this thread - https://ls1tech.com/forums/appearance-detailing/601253-interior-pictures-my-car.html
Yes I searched and looked at all the painted interior's I could find and where the pictures were still working.
Thank you in advance for your help.
But make sure you sand them smooth so they look like fiberglass pieces...
I won't be sanding it smooth though. I don't like the look of it. Honestly all I want is for it to look like the stock interior just black instead of grey.
Here's what some of mine look like:
Bryan
parbreak
Bryan
parbreak
OK??????????????? So don't sand it. But you'll have to use a paint like Fusion by Krylon which is made for painting plastics. Otherwise you're looking at the paint peeling down the road.
If you arent going to be sanding all you really need to do is clean thoroughly, spray an adhesion promoter, spray a primer, and spray color.
I would try to find a high durability spray paint because the biggest issue I have seen is wear. Paint just doesnt stand up to a beating like the bare plastic pieces will. You will get alot of noticable scratches and rub marks.
But most importantly is all the other little things to consider. You're seats will still be gray, you're carpet and headliner will still be gray, are you going to dye you're dash or find a black one?
Personally I wish I had never painted a single interior piece I would rather now live with the boring gray than touch up the black all the time.
i promise you wont be disapointed if you prep then color...it looks great and not out of place. btw black is the ONLY color i would recomend for this type of mod...so good choice
ooooor....you could go to a junk yard and rip out a black interior...im getting the feeling you dont like your gray and just wish it was a different color...you can buy normal stock black peices for your interior...ebay has stuff like that...you just have to look
I haven't had a problem with scratches or rubbing since.
JC
( ended up re-doing door panals all black )
After x-mas Im gonna re-carpet the car, and get my headliner re-done. While all thats out it will be the perfect time to spray the dash... Then It will be done besides the seatbelts, which Im up in the air about.
Bryan
parbreak
My seats were redone in a custom black leather, in that post I mentioned I'm buying black carpet and a black headliner, black seatbelts, and my door panels are Ebony and from a 2002 Trans Am. My rear seat delete was covered in a black carpet as well. So once I do the panels everything will be black.
Like I said I just want the car to look like it came from the factory pitch black but it costs way to much and you could end up with pieces that aren't in as good condition as what I already have.
Thanks, when I get done the only thing that wont be pitch black will be my seats, which are charcoal. I was thinking about some charcoal floor mats with a white fire chicken on them, and then some white faced gauges, white shift **** from hurst, and some phantom gauges from autometer on the piller...
if you are looking for some paint in a rattle can i think duplicolor has some, and i have seen some good results with SEM paint http://www.sem.ws you will probably have to go to a specality store for the SEM paint.
bulldog comes in a rattle can as well, i think you can find it at basically any automotive parts store.
i can post some pics of my interior when i get my car back from the body shop tomorrow or friday.
i really had good luck with the whole sherwin williams experience everything was real easy.
good luck
