Installing halos?????
Old Nov 10, 2006 | 12:37 PM
mannys_z28's Avatar
Default Installing halos?????
OK, I am trying to get these things on but the HALOs have a positve and negative wire I am supposed to connect to the negative and positive of the running/turn signal lights. my question is HOW?????? do i splice wires or do I insert them where the bulb goes. the instructions that came with them suck!!!!
Old Nov 10, 2006 | 01:06 PM
bene's Avatar
Trunion King
You can connect it to the pos/neg wires of you fog lights so you can turn them off/on as you please.
To give you an example here is mine...
And yes, you have to splice the wires.
Old Nov 10, 2006 | 01:21 PM
black00ssFL's Avatar
That's what I did with mine. To make it very easy just go to any autoparts store and head to the electrical section. They have "taps" that are blue in color. They go over the wire you want to tap into and the wire for the halos will slide in next to it. Then you take a pair of pliers and squeeze the metal blade down into the tap and viola, the two wires have been connected without any cutting, splicing, electric tape, soldering, or heat shrink tubing.
Old Nov 10, 2006 | 01:35 PM
StrobinSS's Avatar
Yeah just use what he's talking about . . . "scotch locks"
Old Nov 10, 2006 | 02:29 PM
Hugger Z's Avatar
That exactly what I just used when I connected mine last night. For the moment they are spliced into my DRL (orange lights on the front) circuit. Eventually I want to wire them up to another Fog light Switch on the interior so I can turn them on and off as I please.
FYI on my 99 Camaro for the DRL circuit, the brown wire has constant power and the blue is switched (for turn signal) and black is the ground. Pics of the Halos in action can be seen here: https://ls1tech.com/forums/showthrea...2&page=2&pp=20
Old Nov 10, 2006 | 03:22 PM
mannys_z28's Avatar
cool got the wires spliced and all is hooked up. although there is this gap around the housing. is this one of those things I have to deal with. it wasn't there with the original headlights in place.
Old Nov 10, 2006 | 03:25 PM
There's a gap with mine too, you won't notice it after awhile, give it time.
Old Nov 10, 2006 | 03:28 PM
mannys_z28's Avatar
Can I see a picture of yours? i wuold like to see what it looks like on other Z28s..
Old Nov 10, 2006 | 03:34 PM
i'd have to get back to you on that. Don't have a current pic of her with the halos and i'm about to head out of town to S. Fla for a wedding tomorrow. If no one else chimes in and sends a pic to you i'll get one by the beginning of next week.
Old Nov 10, 2006 | 03:48 PM
mattsls1's Avatar
Mine are wired up with the fog lights. But I can't turn my fog lights on unless my car is on. And when my car is on my headlights are always on....opinions.
I also used the stock brackets. The aftermarket ones are rediculous.
I knew it would have a gap but I don't really notice it.
Old Nov 10, 2006 | 04:46 PM
Brian2006's Avatar
I wired mine to the running lights.
To fix the gap, I just put about 5 washers in between the bolt/screw to act as a spacer and push the halo a little further out.
Old Nov 10, 2006 | 07:12 PM
mannys_z28's Avatar
Ok, I will leave it as is. I do like the look, just wish they fit tighter than that. Pics coming soon. Also, any idea where I can go and learn how properly set up the headlights??
Old Nov 10, 2006 | 07:13 PM
Brian2006's Avatar
Ok, I will leave it as is. I do like the look, just wish they fight tighter than that. Pics coming soon. Also, any idea where I can go and learn how properly set up the headlights??
did you try my suggestion? It's not that hard
Old Nov 10, 2006 | 07:14 PM
mannys_z28's Avatar
I will give it a shot. I was actually thinking of finding a longer housing bolt and some washers like you said......
Old Nov 4, 2009 | 12:50 AM
waynotcars's Avatar
For the gap I just took the rubber off my factory headlights and silicone adhesived it to rubber on halos to make it drop down further and fill the gap. easy and it worked great.
Old Nov 4, 2009 | 12:51 AM
waynotcars's Avatar
I want to put halo rings around my factory fog lights. does anyone know if they make halos that size and where I can get them? If not, is there an aftermarket fog light that will fit the factory hole with halos? thanks
Old Nov 4, 2009 | 12:53 AM
ls1freak33's Avatar
i hooked mine up two days ago but i hooked it to the parking light instaed of the fog lights thought it would be better if i wanted the halos on without the fogs but either way is good
