96 hood fits 98?
if it was self explanatory then i wouldnt ask...thanks for being an *** anyways.
im sure i might run into some issues by the headlights but my main concern is the latch location as well as the hinges...if i can get the back to sit flush and the hood to latch it shouldnt be too difficult to mod it to look original...any help would be appreciated
im beginning to think that the top of the lights may cause some clearance issues...possibly have to cut some webbing...ima call a few people tomorrow see if i can get ahold of a dinged up hood to do some test fitments and get a positive answer or at least a clue as to what to do...i reallly wanna make this work and i think its gonna look bad *** when i do...i like the scoop on the newer hoods better but those bubbles are killing me
not to be a dick but people seldom respond with pertinent information...always trying to tell me what to do with my car..lol if i wanted a cowl hood i would buy one....i personally dont like the way they look on f bods and would never get one....
all im looking for is someone who has done this conversion before or possibly tried to and what problems( if any) they have run into...
thanks
The hoods are different for the 93-97 and the 98 and newer camaro's. The nose and fenders are also different, to use the earlier model hood, you would need to convert your car back to the earlier model.
~Jeanie
if i could get it seated properly it will be easy to mark off where i need to mod it...one of the body guys at the shop can work wonders with fiberglass...thanks
well i have a 00 ss and want to go with a 96 ss hood...not a z...
but like i was saying if the bolts and the latch line up to factory locations it should be fairly easy to do the mod work...im capable of doing all the cuts and shaping but would require the body guy to do the fiberglass...im sure i could do it if i tried but id rather have a pro do it on my car and learn on sum scrap pieces at the job...
If I were to go about doing it myself, I would just do some fiberglass work/bondo over the humps to make it look flatter and sleeker. If you start with a 93-97 style hood you are gonna have to do alot to make it fit and look right.
