H4 and H7 bulbs..
Also, look at the actual lumens output and not just the wattage.
H4 has 3 prongs
* one prong is the positive for the low beam filament
* one prong is the positive for the high beam filament
* one prong is the common ground for both filaments
To turn on the low beam filament, wire up the low beam positive prong to a positive 12volt source and the common ground to a good gound.
To turn on the high beam filament, wire up the high beam positive prong to a positive 12volt source and the common ground to a good gound.
To turn on both filaments, wire up both positive prongs to 12volt sources and the common ground to a good ground.
H4 has 3 prongs
