LED Gauges 8000k HID Install Pictures
I'm 95% sure it's hard on the bulbs. I will look into it later tonight and post up.
The reason I say this is because the ballasts will quickly spike the voltage to start the bulb. If the gases are already hot in a recently turned off bulb, the arc doesn't take as much energy to start, so you're shocking a hot bulb with more than it really needs. Again, this is my reasoning, I will look more into it tonight.
Originally Posted by slonomo
So are the stock fog light housings on a 2002 Camaro projectors, if so, how do they compare with Audi, BMW, Corvette, etc. projectors?
The fog light projectors will not work well with conventional HIDs. I believe they hold an H13 bulb, which is pretty damn small if you've ever looked at one if you've changed it out.
If you were to squeeze a D2S bulb in there, you'd probably have to cut away too much of the internal reflector housing and probably run the bulb into the cutoff shield. If you got aroudn that, then you'd still have to position the arc in the proper spot for focus..... basically it would be a mess.
Also- You can actually over-saturate a projector housing by using too bright of a bulb, and I think this would be one case where that would happen easily......
Many companies make a kit for the fogs. Slonomo was probably asking about using the stock foglights as primary HID projectors. In that case, I would not use them. Kits sold for the stock foglights will be ADAPTED to work with the fog light projectors. Specifically, it'll be a D2S bulb adapted for that particular bulb base (I believe fogs are H13). They will not produce HID lighting as well as projectors designed specifically for D2S bulbs.
However, they will help match color temps and balance out the lighting from an appearance standpoint. I know this is important, because I did the same thing in my car with halogen bulbs back in the day (2 low beam hyperwhites, 2 high beam hyperwhites, 2 fog leam hyperwhites). To this day I still keep "hyperwhite" bulbs in the fogs even tho they are useless from a lumens standpoint just so I can have foglights that come close to HID color.
