Side stripes
Old Dec 25, 2006 | 12:43 AM
Camaro Ryder KV's Avatar
Default Side stripes
Hey guys, i got the side stripes for christmas from my girlfriend, they are awesome!! they are the ones that go all the way back, not stop at the door handle. But i have 1 problem, what can i do if i lay it down wrong? i have installed alot of decals, but none this big, always winshiled banners and stuff, i always hit it right on the money each time, i never messed up.....but these are huge and i know i am going to run into some problems.......any installation tips? any help would be appreciated.........and to the people who bash side stripes, i dont care about your comments, im simply asking for help installing them. So dont bother to post if u have something negative to say, when they are on, i will put up pictures, and then u can tell me they look like **** all u want, but for now, i just need help.
thanks
Kevin
THEY ARE ON GUYS!!!!!!!!!!!!!!!!!!
Old Dec 25, 2006 | 01:33 AM
StripedZebra's Avatar
Well, when i did the stripes on my 97, we messed one up. So the guy at 3rdgendecals gave me a new one for half price.
When you go over the breaks for the door, dont cut it before hand. Cutting for those breaks is the last thing that you do; get it all layed/stuck down first.
Lay everything out first. Do one side. Once you've done one side, just get some measurements and copy it to the other side.
It was definately hard. We had to trim some (the gap on mine where the z28 is is wider because we had to trims some out).
If you have any specific questions just ask. Ill try and answer them for ya.
Old Dec 25, 2006 | 02:55 AM
Hype's Avatar
Hey, I have those from 3rdgendecals too, I like them a lot!
You can search around here for how to do it, I found a few write ups before I attempted mine. But anyways, here is some quick advice:
Have someone there to help you, you are on a bit of a time line before they dry and you want all the hands you can get.
Make a solution of water and soap, mostly water if i remember right, and put it in a clean spray bottle, as long as you keep everything wet you can move it around until you are satisfied.
Before I put them down for good, I got them where i wanted and taped them to the car. Then I put reference pieces of tap along the car right above and below the strip, so I'd be able to match it up to those spots.
Next, basically spray down the area on one side of the car with the soap/water mix, lay it down, spray over top, and align it how you want, then start removing the air bubbles with the tool provided.
Do one side at a time then measure it to match the 2nd side as close as possible.
I have some pictures of my stripes on my cardomain if you want to see how I lined mine up... I chose to keep the gap on the tire well the same and followed a horizontal line instead of following the car window...
Good luck and be sure to post up after pics!
Old Dec 25, 2006 | 09:32 AM
SS LS1's Avatar
Exactly!! That's the secret. I do the same except I also use a wide sharpie pen and make a line from the decal directly out to the reference pieces of tape giving you something exact to line up with when installing the wet decal. The sharpie pen just goes across the overlayer of paper and not directly on the decal. Also jay recommends you mix 10% or so of alcohol with your soap and water mixture to help the solution dry faster and provide a good bite between the vinyl and paint.
Good Luck!
Old Dec 25, 2006 | 07:47 PM
aweosme tips, thanks guys.......anymore
Old Dec 25, 2006 | 10:41 PM
Havok2's Avatar
Just Keep It Wet
I Did My Own
Old Dec 26, 2006 | 12:00 AM
Rickys S/C Z28's Avatar
yes before you do it make sure all the wax is off your car (do this buy washing it with dawn) and make sure it is as clean as you can get it, i clay bared mine first. then just keep it wet. you are going to need more then just you so get some help cany wait to see the pics
Old Dec 28, 2006 | 01:40 AM
got the stripes on guys, HOLY $hit, 4.5 hours put them on!!!!! pain in the ***, id never do it again....well i guess i would since i know the measurements now,lol but u know what i mean........ill get some pics in a few minutes, its nite time but i think they will look good
Old Dec 28, 2006 | 01:57 AM
Old Dec 28, 2006 | 02:06 AM
88monte's Avatar
liqour enthusiest
looks good
Old Dec 28, 2006 | 02:28 AM
SpaZMaN's Avatar
i like it.
Old Dec 28, 2006 | 12:35 PM
Taubr Unit's Avatar
hell yea, i want them!! Where did you buy them from and how much were they????
Old Dec 28, 2006 | 02:29 PM
new pics!
Old Dec 28, 2006 | 11:39 PM
ITSA6's Avatar
just go really slow and carefully probably a two person job maybe?
Old Dec 29, 2006 | 12:22 AM
Hype's Avatar
4.5 hours?? what took you so long
I think it took my friend and I a little over an hour for the first side and a little under for the second.
At any rate, it looks good from the pictures... have you put it out in the sun yet? I did for mine and I read you are supposed to to get most the air bubbles out.
ok, back to what I was doing a minute ago
Old Dec 29, 2006 | 12:26 AM
yes 4.5 hours, we were just having some really bad luck i guess, it was late, but i dunno, just didn't seem to want to cooperate. thanks, it does looks good! keep the comments coming guys, i want to see what u guys think
Old Dec 29, 2006 | 03:53 AM
anyone?
Old Dec 29, 2006 | 04:52 AM
i like it good job!!!
Old Dec 29, 2006 | 01:51 PM
thanks bud
Old Dec 30, 2006 | 01:15 AM
All i see is the night pics. Did you post better ones?
