C6 Steering Wheel in Fbody
Old Jan 2, 2007 | 10:21 PM
ProjectCamaro's Avatar
Default C6 Steering Wheel in Fbody
Anyone know if you can make the C6 steering wheel fit in the FBody? I have a '99 Camaro and the steering wheels is beyond ugly and I would hate to leave it.
I tried searching but as always I get a "408 Request Timeout"
Old Jan 3, 2007 | 11:53 AM
johnpr's Avatar
i would think that it should match up to the steering colom but you might have to mess with the wiring, i doubt its completely plug and play but i could be wrong. the steering colom should be the same as gm hasnt done any major changes to it since the 70's?
Old Jan 3, 2007 | 12:29 PM
I don't mind it not being a stright plug n play. I'll do the work to make it fit. I just absolutly hate the stock wheel.
Old Jan 3, 2007 | 03:13 PM
radz's Avatar
Not sure how true that is, I havent driven an C5 in about 2 years but last I remeber the C5 steering column moved when the key was put in and pulled out to assist the driver.
Old Jan 3, 2007 | 03:49 PM
HAMRHEAD's Avatar
I'd be curious to know as well
Old Jan 3, 2007 | 03:54 PM
Cobra4B's Avatar
FWIW you cannot put a C6 wheel into a C5 and you cannot put the '06+ 3-spoke nice C6 wheel into an '05 C6 and retain the airbag.
It sucks... b/c I'd love to have the C6 wheel w/ a C5 flags in it.
Rocko71's Avatar
Yeah, keep us posted if you decide to go for it. Sounds like a great idea.
Old Jan 3, 2007 | 05:25 PM
SRfastZ's Avatar
i like the steering wheels from the 98s they are smaller then the 2000 up
Old Jan 3, 2007 | 05:29 PM
SSNISTR's Avatar
I would so love to do this....I helped a freind put a '00 steering wheel in a '99. It wasn't so bad....had to change the airbag though.
Old Jan 3, 2007 | 05:39 PM
AnimalSS's Avatar
What about an '06 or '07 Silverado / Avalanche wheel? Even those look better than that Camaro wheel.
Old Jan 3, 2007 | 05:43 PM
SSNISTR's Avatar
2000 and up has a different one then the 93-99.
Old Jan 3, 2007 | 06:31 PM
That's what he was saying.
Old Jan 3, 2007 | 09:12 PM
SSNISTR's Avatar
Oh I misread it lol, my bad....I think the '99 and older ones are even uglier then mine lol.
Old Jan 3, 2007 | 09:32 PM
white_camaro's Avatar
i like the smaller wheels too. its nice to be able to do a u-turn without the steering wheel giving me a leg massage.
Old Jan 3, 2007 | 09:37 PM
johnpr's Avatar
ive seen those, i meant that i think the splines and diameter of the metal shaft should be the same, they have changed certain things like the telescopic column's and even the amount of positions for tilt, ( in the 80s they only had like 3 or 4 i think there is around 5 -6 in my t/a) so your right the column technology has changed but i dont think the mounting has.
Old Feb 8, 2007 | 02:32 AM
GoFast908Z's Avatar
why can't you retain the airbag?
Old Feb 8, 2007 | 09:24 AM
Cobra4B's Avatar
^ Different designs and connections... it's been attempted and confirmed that you can't transfer the new '06 wheel to even a '05 C6 while keeping the airbag.
Old Feb 8, 2007 | 10:09 AM
GoFast908Z's Avatar
what about changing the whole airbag system to be fully 98 or fully 06?
Old Feb 8, 2007 | 10:43 AM
GR33N GoblinM6's Avatar
cant change the column either because the C6 is keyless
Old Feb 8, 2007 | 12:29 PM
Cobra4B's Avatar
The C5 key isn't in the coumn... it's in the dash.
