Something Im doing is causing scratches
1, Hose down the car with water, then fill up a bucket with Meguairs (sp?) carwash soap
2, use a sponge (kind of an old one) and scrub it clean
3, rinse the soap off and dry with a leaf blower
4, apply wax, (the stuff im using right now is the Dupont teflon spray wax) with a cotton cloth
5, when wax is ready to wipe off I use microfiber towels
And that is what I do when I normally wash my car, it seems that every time I wash it more and more swirling and scratches appear all over my paint.
Is there any problems you see with the steps above?
i would try a new sponge
Make sure you cotton cloths are 100% made in USA cotton. They won't be auto store cheapies.
Also make sure your microfiber is high quality.
__________________________________________________ ______
Here's the process I use to wash:
-Wash wheels/tires/wells first to prevent spotting on paint and glass
-Don't use the same mitt or bucket for wheels that you use on your paint. The brake dust, etc. from your wheels will cause scratches and swirls in your paint.
-Using foam gun, cover vehicle in a thick layer of foam (optional)
-Use two buckets for washing paint. One with a soapy mixture, the other with plain water to rinse the mitt between panels.
-Never use circular motions. Always wash, dry, and wax using front to back and top to bottom motions.
-When vehicle is fully cleaned, allow a slow, steady stream of water to flow over each panel...sheeting the majority of the water off
-Use the leaf blower to blow all water from flat surfaces, mirrors, lights, etc.
-Remove any remaining water with a waffle weave drying towel and detail spray
*The less you touch the paint, the less chance of marring*
Keeping a good sealant and/or wax on the paint will assist in cleaning and reduce chances of marring.
