Emblem installation
Old Jan 22, 2007 | 11:59 AM
bee-stro's Avatar
Default Emblem installation
I'm picking the car up from the paint shop this week and i have a couple of questions on how to apply emblems to the car. I have emblems from Dragonz8 and i wanted to know:
1. What are the exact locations too apply my SS fender emblems, and rear panel emblems?
2. Is there any type of prep work i need to do before applying the emblems?
3. Do i need to heat the emblems or surface before applying, the temperature in my area is around 45 to 60 degrees.
4. Are there any other tips for appplying emblems
Old Jan 22, 2007 | 12:28 PM
NviouSS's Avatar
i would make sure the surface is clean of any debris. also spray some soapy water where they are going to make sure you get them place right and level.
Old Jan 22, 2007 | 03:37 PM
blown 346's Avatar
I wouldnt heat the area, I would just use alcohol pads to clean and prep the area.
The side embelems should go right in the center of the fender behind the front wheel. Make sure that it isnt flush with the side molding, There should be a small gap.
For the rear embelem, that should go underneath the passenger tail light pff center to the right. I would check out some pics, as I dont know how else to explain it.
Old Jan 22, 2007 | 03:59 PM
bee-stro's Avatar
i get what you are saying. Is there a way that i could get the exact location or mesurements
Old Jan 22, 2007 | 04:47 PM
AnimalSS's Avatar
Get someone to measure there's for you. I don't have time right now but, if you still haven't gotten an answer by the time I can measure mine, I'll post the info.
Old Jan 22, 2007 | 09:15 PM
pwterz28's Avatar
i checked in my service manual for you and it only gives the dimensions for the z28 and firebird nothing on the ss
Old Jan 22, 2007 | 09:23 PM
bee-stro's Avatar
you think if i were to check my ss manual it would say so?
Old Jan 23, 2007 | 02:05 AM
blown 346's Avatar
No, the manual wont tell you. I would go to your local body shop, or a GM certified body shop and they can give you the specifications on placement.
Old Jan 24, 2007 | 08:47 PM
bee-stro's Avatar
you think you can, when you get sometime. i tried to get them off my buddy's z28 but his aren't the same.
