Painting Rotor Hubs???
JacobK
I painted mine. You should install them 1st and see where the brake pads make their track, then remove 'em and mask that "swept area" with masking tape and spray bomb it.
You can use high heat or normal black spray paint. I didn't use high heat on mine and it still looks good after one year.
So I see no need to paint them if they are zinc coated
Mine were, still had some rust spots.....so I paintd them.
Black makes the rotor look sorta tiny since it no longer is as noticeable.
Though silver doesn't always match up on the car, especially if the silver doens't match the silver already on the car.
Did you seriosuly wash it, like until the latex gloves you were wearing started to melt off?
Also doesn't high-temp paint and caliper paint not interact properly when sprayed on top of each other?
I do believe that caliper paint is a paint on by itself paint.
I would think though that if you did clean it properly and when you said high temp and then caliper you were meaning not at the same time on top of one another but one after another when they chipped off, that it was definately the zinc coating.
+1 for POR-15. Hit it with a hammer and it won't come off. Semi gloss black. Did the rear with it as well as anything else that would have surface rust on it. Also doesn't high-temp paint and caliper paint not interact properly when sprayed on top of each other?
edit: I went out to the garage to get a couple pics and the camera batteries are dead. I'll have to get back to ya on that.
