Center console
Old Feb 13, 2007 | 06:37 PM
01blackformula's Avatar
Default Center console
how to you get the center console out of the car?
Old Feb 13, 2007 | 07:06 PM
3.4camaro's Avatar
there are 2 bolts below the radio on either side. take em off
then pull the ebrake ******* hard so its vertical
2 bolts in the console bin
pull it out.
if you cant get the ebrake off, undo the clicker with a screwdriver. it should make it easier to get vertical
Old Feb 13, 2007 | 08:10 PM
Brian2006's Avatar
With an A4 all you gotta is pull the pin out the shifter ****, pull the **** off, put it in neutral with the ebrake on, undo the bolts under the change slot, and carefully angle the console out.
Old Feb 14, 2007 | 11:24 AM
thanks for the imput im gonna go try it.
Old Feb 14, 2007 | 12:27 PM
Brian2006's Avatar
Alright let me know.
And tell Nate in the nbm t/a what's up for me
