Clear Corners
Old May 10, 2007 | 06:22 PM
Sweet71's Avatar
Default Clear Corners
Which clear corners do you have and do you have any problems with them, what in your opinion are the nicest ones?
Thanks Guys
Old May 10, 2007 | 07:12 PM
LS1BADZ's Avatar
I went with "REVOTEC" on ebay....unbelievably flossy!!! I can't wait until he gets the black housing ones in!!
Old May 10, 2007 | 07:34 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
I got both my front and rear clear corners from AfterThoughts Auto (sponsor). They are very high quality (can't tell them from factory pieces other than color) and have never leaked in the 4 years I've owned them (course the car has never seen the rain )
Stay away from the cheap versions on eBay that are made from flourescent light diffuser material glued to a factory backing - They don't look near as good and I've heard they have much problem with leaking.
Not saying that the eBay version mentioned above are necessarily the crappy ones...
Old May 10, 2007 | 09:10 PM
MannyZ28's Avatar
If you do get a cheaper one...silicone the hell ouf of the edges. Also, silicone the plug with the big bulb into the housing, that was my major point of leakage.
Old May 10, 2007 | 10:47 PM
BlackBADaSS02's Avatar
I got a set off ebay, the brand was kayee. I used clear silicone around the edges. Its been over a year with no fogging problems at all.
Old May 11, 2007 | 01:38 AM
Sweet71's Avatar
cool thanks guys
Old May 11, 2007 | 02:06 AM
Mistacamawo's Avatar
ive got the smoked corners from ebay, from the user eurosportgarage
no problems so far
Old May 11, 2007 | 08:39 AM
LOHRTBT's Avatar
I have had 2 full sets from Afterthoughtsauto and they SUCK! Both sets leak like the titanic and it in turn causes the reflective backing to fall off and then they are white on the backing rather than the shiny chrome look. There is water in them all the time and it kills bulbs. they SUCK!
On that note...anyone making a new front DRL/Signal housing that doesent leak the same way?? Mine leak like crazy. Just want new ones...I will even buy a new stock one andsilicone the hell out of it.
