Best product for swirl marks
The swirl mark lines will be tightly packed together with the clear coat appearing cloudy or hazy. In some instances, they can be inflicted by a mild rubbing compound on the rotary polisher when used to level the clear coat after wet sanding or during the removal the spider scratches.
In the case of spider scratches, these are more evident as they appear more pronounced with spaces of clarity between each line on the surface.
Here is a thread discussing and showing the differences between the 2 types of blemishes.
http://www.ls1gto.com/forums/showthread.php?t=140348
In the case of our TC-8 Swirl Cutter, it is formulated to remove the ultra fine lines of these blemishes up to 2000-2500 grit scratches when used with a lightly misted orange pad on the Porter Cable buffer. You will notice the increasing clarity on the clearcoat moving at the rate of 1"/second at the surface at speed 5-6 on your PC.
If you're unable to remove the more stubborn scratches, you may have reached the limitation of the Swirl Cutter's ability. Using the least aggressive treatment methods first, you may have to step up to the yellow "medium cutting" pad/stronger cutting abrasive for removal. We personally use 3M Perfect-It II Rubbing Compound in this phase. The 3M has a cutting ability of 6.5 compared to the Swirl Cutter's 4.0 on a 10 scale. Once satisfied with the removal of your blemishes, you may notice some micro-marring and compound swirling (infliction of tiny scratches) with the use of this combo. At this time, you may now return to the orange pad/SC combo to remove swirl marks and restore clarity to the finish.
If you plan on doing the whole car by hand, then Tropi-care TC-8 is a great choice for removing light swirls.. Their TC-3 is also a great choice for a sealant to finish it off with.
I would recommend picking up a DA from Tropi-care, along with some pads, their TC-8 and TC-3.
then:
wash
clay
!swirls
seal
wax
admire
Along the left edge of the lid, we did use some 2000 wet/dry sandpaper previously to level off the cat scratches. A quicker method of recovery can be achieved with the orange pad and 3M on the rotary polisher. However, this is only recommended for experienced polisher users. To remove the compound swirling from the polisher, we would follow up with PC regimen.
http://www.ssrfanatic.com/forum/show...ighlight=39066
I'm sure Tropi-care's TC-8 works just as good on lighter stuff as mentioned.
