Hood Prop Rod?
Old May 17, 2007 | 05:46 PM
JoeMack's Avatar
Default Hood Prop Rod?
I have an SLP Ultra Z hood that needs a prop rod. Does anyone have a suggestion where I can find one? Thanks
Old May 18, 2007 | 10:04 PM
GETGONE's Avatar
Why would it need a prop rod when the factory setup uses gas shocks to hold the hood up? Maybe you just need new or stronger shocks to hold it up.
Old May 19, 2007 | 02:33 PM
JoeMack's Avatar
The original lift supports work fine but the driver side support, is causing the hood to get a "wave" in it, if I leave it attached. To much pressure I guess.
Old May 19, 2007 | 02:43 PM
dhdenney's Avatar
I used a piece of conduit for a prop rod for a while. It was 1 1/2" round and I set it in the tallest part of the latch on the bottom and the corner of the hood side latch rested in the other end perfectly.
Old May 19, 2007 | 02:54 PM
GETGONE's Avatar
Then you need less pressure like the shocks used on the SS hoods. SLP should still sell them.
Old May 19, 2007 | 03:13 PM
dhdenney's Avatar
Didn't know there was such a thing. Wish I had known that a long time ago! Might have saved me from the ghetto prop rod I just described!
Old May 19, 2007 | 09:00 PM
JoeMack's Avatar
I talked to someone at SLP and he said that he never heard of the problem that I am having. I also asked about different lift supports and he said that he did not know of any that will work that have less pressure.
Old May 19, 2007 | 10:22 PM
GETGONE's Avatar
Well I don't know who you talked to but I know on all the Firehawk and SS hoods they went with lighter pressure shocks since they had a ton of take off hood shocks from the heavy steel Z and base Trans Am/Formula hoods that were replaced with the light weight fiberglass/composite hoods.
