all your custom trans am interior work in here
#321
Can't wait to see the rest of the shots!
#322
#324
Here's my latest one, I fit a 7" LCD in our 1.5 DIN spot without relocating anything. I was the first figure out how to put blue gauges in a T/A and LED interior lights too. Next project is a carputer with 7" LCD VGA touchscreen. Glad others have done this, so this one should be pretty easy...er
#326
i know this is an old post but can anyone assist me in how he did this set up i think he used a 7 in monitor and external dvd player under the seat. is it just hooking up the avs and then putting them in? also has anyone customized the headrests of racing seats ive seen decals that you put on anyone have experience with this?
#328
#329
#332
Go check out the stuff DragonZ28 has to offer on here. He is a long time member & sponsor. He made me a nasty little nitrous switch plate that could be illuminated from behind but its far from the same type of work Humount offers.
#334
I finally got the trim rings for the vents from boyd (the last set he said he had and was ever gonna make by the way). These things are pretty thick and heavy, what kind of glue/epoxy did you guys use on them?
Also, I had replace the big plastic piece that surrounds the gauge cluster a while back (the big assembly that holds the far left vent). When I got it, I was looking for an ebony piece but read somewhere that that hard plastic piece was the same basic charcoal color no matter what color interior you had. After looking at some of the ones on here with ebony interior, mine looks a little off from the rest of the dash. Is that normal? I don't want to install the trim ring in that vent if it doesn't really match.
Here is a pic:
http://i79.photobucket.com/albums/j1...n/dashtrim.jpg
Here is a pic:
#335
That looks like a piece from a 97-99 , when the charcoal was really light . Could be a 93-95 too , its not as light as the 97-99 , but lighter than ebony . At any rate , definately not ebony .
#338
This part is so cheap , painting it the corect way would cost more than buying different part the correct color . If your **** , GM Ebony is rather difficult to match given its sligtly brownish hue .
