LS1 vs LT1 tail lights?
...you just need to do alittle re-wiring, its not hard at all
All i did was tap into the low filament wire (middle one) on the main taillight socket and run a wire to the empty slot (middle one) on the turnsignal socket. So now the blinker stays on low filament too. It looks wayy better than just having the corners lit up, and it was really easy too.
http://www.fquick.com/images/vehicle...jpg?1166590853
>>>NO NEED TO QUOTE PICS!!!<<<
The lines on ls1 lights dont even line up right, the lt1 style do.
Lt1 style are nicer by far.
wtf!
I just did mine in 5 mins. Here is my halfassed write up.
Look for the brown wire that is labled B on the harness. Now look at the light the harness that was used as a turnsignal on your ls1 lights. There should be an empty slot labled B with a green stopper in it. Pull the stopper out. Inside you will see a very small wire. Get a spare peice of wire you prob have laying around the garage and place it in the hole making sure that the new wire is making a good contact with the wire in the harness. After you get the wire in the hole make sure to put a good amount of blacktape around the socket to makesure its not gonna come out. Now you need to go back to the other light and either cut the wire labled B that is brown or carefully peel the insulation off using some pliers. ( This is what I did). Then you need to take the other end of the wire and and just wrap it around the Brown wire. And your done
Make sure to blacktape this wire too. I am assuming you know to strip the wires so I left that part out
Turn the headlights on and smile.
Sounds kind of confusing in writing but once you look at it, its easy to understand. I can get some pics if you want.
Not good and lighting wasnt that great so heres what i got!
