LS1 vs LT1 tail lights?
Personally though I think the exports look the best and I have owned them on all of my Camaro's. Only downside to them is their price.
me and another member gave step by step directions to do this. It is easy as hell and takes less than 5 mins. If you can strip a peice of wire and remove your tail lights and spare tire you can do it! Look around on page 2 or 3
Its my ******* thread. lol
I guess I just skipped over it.
I just did mine in 5 mins. Here is my halfassed write up.
Look for the brown wire that is labled B on the harness. Now look at the light the harness that was used as a turnsignal on your ls1 lights. There should be an empty slot labled B with a green stopper in it. Pull the stopper out. Inside you will see a very small wire. Get a spare peice of wire you prob have laying around the garage and place it in the hole making sure that the new wire is making a good contact with the wire in the harness. After you get the wire in the hole make sure to put a good amount of blacktape around the socket to makesure its not gonna come out. Now you need to go back to the other light and either cut the wire labled B that is brown or carefully peel the insulation off using some pliers. ( This is what I did). Then you need to take the other end of the wire and and just wrap it around the Brown wire. And your done
Make sure to blacktape this wire too. I am assuming you know to strip the wires so I left that part out
Turn the headlights on and smile.
Here is a pic of Teri9672's white car:
Here is a black car:
Red car:
Navy blue:
Found the one I was talking about its DEMONBIRDS car:
